Go Back   HeliFreak > R/C Electronics Support > Align 3G FBL System > Align 3GX FBL System
Align 3GX FBL System Align 3GX FBL Flybarless System Software and Hardware Support
Old 10-30-2011, 11:11 AM   #1
Bking1340
Default 3GX/life/pushglo/pin flag
Good day all
Asked the question before, but nobody could realy help me. On my 600LE fbl(3gx) I`m currently using the 2 in 1 with 3000mah lipo receiver pack and 2 dsmj sats only. Want to go as per title - How will I connect this?
Bking1340 is offline        Reply With Quote
Old 10-30-2011, 11:55 AM   #2
jsenicka
what are you using for a failsafe switch to support using the pin flag?
Jim Senicka
Team Captain, GrandRC Flight Team
Align TREX700N - TREX700E - TREX600LE - TREX500 - TREX450Pro
jsenicka is offline        Reply With Quote
Old 11-01-2011, 11:02 AM   #3
Bking1340
This is the pin flag I was talking about: http://helidirect.com/gsb-1030p-gryp...ed-p-24769.hdx seems like pulling the switch will power on. What are a failsafe switch. Or maybe I must ask it this way? I want to use a pushglo for the glowplug and a 6.6v life battery to power everything (pushglo and electronics) and a switch to switch on and off (Dont want to plug in or pull out the life battery wire on the 3gx unit all the time) So what switch can I use and how will I connect everything to the 3gx?
My 600LE has the stock servo`s installed which will handle the 6.6v life unregulated.
Old 11-04-2011, 01:44 PM   #4
Bking1340
