Old 10-31-2011, 03:14 PM   #1
flybar-les
Default were to put the throttle channel from a 6ch fut -> V-bar ?
i'm setting up a Trex 700E with V-bar and a 6ch R6106 receiver + V-bar governor on a hobbywing 120esc.
the problem is that i ran out of ports in my full size bleuline V-bar !
i need to put ch3 from the receiver into the 'aux' of the V-bar but the 'aux' is already occupied by the gyro/bankswitch channel.
also i noticed that the bankswitching on the v-bar reacts on the throttle input and/or idle up switch instead of the throttle channel.
i redid everything 5 times by the videos of mrmell and the instructions on the V-bar setup screen but no luck...
can someone hel me out please ?
SAB Gobblin 630 12s Vbar
mCP-X + 130X + mCP-X brushless
DSX9
follow us on facebook !
flybar-les is offline        Reply With Quote
Old 10-31-2011, 04:40 PM   #2
Deet
Get yourself an s.bus Rx and then you have full functions, you can't have Bank switching, Gov selection and throttle on a vbar using normal Rx inputs, you need to do without one of them.
But if you get an R6203SB Rx its a one wire connection into the vbar and you get all functions.
Dave
Goblin 500, Vbar, BLS153, BLS251, Kontronic Jive & Piro
MutliWiiCopter Scarab Stealth Armour, Scarab TriiKopta, Scarab Octa, Scarab Vampire
Deet is offline        Reply With Quote
Old 11-01-2011, 02:45 AM   #3
flybar-les
the heli is'nt mine, i was setting it up for a friend, i never hooked up a V-bar with a seperate RX and a governor at the same time btw...
i did try to let out the bank switching and then put the ESC channel from the RX into the 'aux' on the v-bar but still no result, the banks keep switching when i give throttle/idle up.
and no there are no mixes set in the TX as far as i could see.
DSX9
Old 11-01-2011, 04:19 AM   #4
Deet
Are you on single servo in the radio?
You also need to set vbar to look for throttle on the aux input
Dave
Old 11-01-2011, 12:34 PM   #5
flybar-les
Yes, single channel...
And tnx that's a good tip, i'll try that and see what it does.
DSX9
Old 11-01-2011, 04:54 PM   #6
MrMel
V-BAR Guru
Have a look at the governor with separate receiver video i made, more aimed for nitros in that video, but principle is the exact same.
MrMel is online now        Reply With Quote
Old 11-02-2011, 02:19 AM   #7
flybar-les
hey Mrmel,
as far as i know i did the setup right with the cable from the 'throttle' from the receiver to the 'aux' on the V-bar, compared to your video it all looks like i did it good but if i give throttle my banks switch.
so if i go out of my setup sceen into my live display and i want to set my governor rpm with the throttle curve(off course with no motor connected) i noticed my governor screen disapeared and i saw the banks switching when i give throttle/idleup.
only @ zero throttle the bank is se to "0" and i can see my governor screen...
DSX9
Old 11-02-2011, 02:23 AM   #8
MrMel
V-BAR Guru
Disable bank switching in main screen. Set bank manually to bank 0
That, or copy bank 0 to all and then start to change
Old 11-02-2011, 02:45 AM   #9
flybar-les
yes, i've set it manually to "0" in the bank switch screen and copy bank "0" to all banks but something does'nt feel right at that moment, i suggested to lay off the heli until this was solved...
ok thank you guys for the superb help, i'm going to take a look at it as soon as i can and try the suggested tips !
DSX9
Old 11-02-2011, 02:57 PM   #10
flybar-les
tnx alot guys ! it worked !!
DSX9
