Go Back   HeliFreak > R/C Helicopter Support > Henseleit
Henseleit Henseleit Helicopters
Old 10-31-2011, 06:56 PM   #1 (permalink)
Default 6S/12S connectors
Forgive me, I know this subject has been talked about in the past, but would like your thoughts and opinions on connectors for 6S packs, and to make up 12S packs.
I have been using CC 5.5 bullets for a while now, but I do have to keep a keen eye on them that they do not get too loose.
I have recently heard of several people having them come apart in flight! Not good!
I am going to guess the most popular option is the EC5. Just a shame the blue case is so big and ugly!!
What are you all using?
Cheers all, Rob.
TDRx2, Synergy N7/E7se/N5cTT, Align 450L/550/700e/700n, Gaui NX7/NX4, , Goblin 700/Black Nitro, Futaba 18MZ/ V-Control All on V-Bar's and S-Bus. #0095
rctintin is offline        Reply With Quote Quick reply to this message
Old 10-31-2011, 07:08 PM   #2 (permalink)
EC5 or XT150 - the EC5 dyes easily, so are no problem to turn into your favorite black color...
Edvard R is offline        Reply With Quote Quick reply to this message
Old 10-31-2011, 07:32 PM   #3 (permalink)
Cool, that would be better. Just ordinary black cloths die?
Old 10-31-2011, 08:22 PM   #4 (permalink)
Rit-Dye has proven itself on a number of occasions
Old 11-01-2011, 07:50 AM   #5 (permalink)
I saw a write up on dying the white TDR gears this way.
How would this work, pour X amount of dye in some warm water with the EC5 connectors already in the warm water, let soak for a while ?
I guess from their instructions for fabrics, that hot water in a glass container might work. I have 12 sets of EC5's as I am converting over from Deans on my existing 6S 5000mah batteries and will be using them exclusively on the TDR.
Measure 2 teaspoons dye into 3-cup container. Add 1 cup hot tap water; stir to dissolve dye and set aside.
Place in microwave and set on HIGH for One minute.
Mark
Dusty Shelf queens: TDR2, TDR, Protos Max, Logo 550SX, Protos 500, Jeti DS-16, etc....
mkovalcson is offline        Reply With Quote Quick reply to this message
Old 11-01-2011, 08:40 AM   #6 (permalink)
Mix water with Rit-dye in an old pan, and bring to a simmer. Dump whatever you want to dye in the pan and let simmer for about an hour.
Old 11-01-2011, 10:34 AM   #7 (permalink)
Put marbles in the pan and this will keep the parts away from the bottom of the pan to ensure even coverage of the dye
VControl
Old hand at Planks
Peter
Old 11-01-2011, 10:38 AM   #8 (permalink)
I imagine EC5 connectors are designed to handle heat
Unfortunately I noticed on the packaging for the EC5's that they contain substances known to cause cancer.
So now I have to ask whether boiling them will release carcinogens into the air or should I just keep my hands out of the water.
Then again it could just mean don't let a small child suck on them...
Mark
Old 11-01-2011, 07:02 PM   #9 (permalink)
EC5 for sure. If your flying the with a canopy it shouldn't matter what color the connectors are.
kouasupra is offline        Reply With Quote Quick reply to this message
Old 11-01-2011, 08:11 PM   #10 (permalink)
+1
Sent from my SGH-T959V using Tapatalk
KidHeli is offline        Reply With Quote Quick reply to this message
Old 11-02-2011, 01:18 AM   #11 (permalink)
I think everything heli-related I own has that same warning label. I would guess that there's lead in the metal part of the connectors and who-knows-what in the plastic. I wouldn't let a kid use one as a sucker, especially when it's already soldered to a lipo!
I would boil/simmer the plastic parts outside if you can. I dyed the first set of parts in the kitchen in a cheapo pot (don't dye in anything you plan to cook in again) and I had to cut the dye job short because the simmering dye soup stunk the place up to high heaven.
So, definitely dye/simmer/boil them outside if you can -- so hopefully you have a barbecue grill with a side burner or an outdoor kitchen.
ElectricSheep is offline        Reply With Quote Quick reply to this message
Old 11-02-2011, 06:31 AM   #12 (permalink)
Good call and thanks for the extra information.
1. I have some old cheap pans I will never use again.
2. I have a grill with a side burner ( that I've never actually used )
The earlier suggestion about using marbles makes sense too!
For those of you who have done this, did you get liquid or powder and how much did you use?
Mark
Old 11-02-2011, 07:11 AM   #13 (permalink)
Either is fine - powder just use one baggie, and liquid just use the whole bottle. It can be re-used over and over.
Old 11-02-2011, 07:15 AM   #14 (permalink)
So you pour the dye solution into a container and warm it up again?
Mark
Old 11-02-2011, 07:20 AM   #15 (permalink)
True, I fly with a canopy on, so does this mean I should leave my Helis with crap untidy wiring as well?
I take a pride in my Helis and the build quality and look is equal to how they fly. When you have a lovely carbon and machined alloy airframe, I don't want bright blue battery connectors!!
Old 11-02-2011, 07:23 AM   #16 (permalink)
Yep - a coke bottle works well, if you keep it somewhere where nobody takes a sip of it... come to think of it, it might be illegal in some areas to do that... but you get the idea.
Old 11-02-2011, 07:25 AM   #17 (permalink)
Pink?
Once you go black...
Old 11-02-2011, 08:15 AM   #18 (permalink)
Only if it is shocking Pink!!
Old 11-02-2011, 08:42 AM   #19 (permalink)
Damm
I knew TDR's are the pinacle of quality, but i didnt realise that there is so little to concern yourself over that ones attention turns to the colour of the connector.
This just makes me want one even more!!
minicopter DIABOLO LOGO 550sx
scorpion spirit futaba IISI
smsodhi is offline        Reply With Quote Quick reply to this message
Old 11-02-2011, 09:28 AM   #20 (permalink)
I think there is a quest for perfection that is a bit pervasive in this group.
Mark
