| 250 Class Electric Helicopters 250 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
Just upgrade my Futaba 10C from PCM to 2.4G. The R6106HFC looks cute and neat. I like the single antenna.
However, when I hook it up to my 250 FBL, the ESC/Motor seem not work at all. There's no sound when connect the battery. Finally, it back to normal after I changed the receiver's mode from High Speed to Low Speed. So, Scorpion ESC cannot work with R6106HFC in HS mode? Anybody can feel the difference between HS and LS? The servos are 3 MKS 545 and 1 DS420. Thanks. |
I am surprised about that, since ESC's don't have limitations like some older servos. I would check out the Scorpion specifications.
Since you find it works in LS but not HS, I am afraid you may already have the answer! |
Anybody has the same issue with HS receiver mode?
