Go Back   HeliFreak > R/C Electronics Support > bavarianDEMON/HeliCommand
bavarianDEMON/HeliCommand Factory Sponsored Bavarian DEMON and HeliCommand Support
Old 11-09-2011, 12:05 AM   #1
watdazit
Default HC3SX setup problem
I have come to that exciting part where I am on the downhill run of setting up a new heli and my first HC3SX. I have setup HC 3D's before so am somewhat familiar with Captrons computer interface.
My problem is that the bars in the diagnose screen are not moving in a manner which corresponds to the Tx.
Firstly my installation uses 2 Spectrum satellites. They bind OK. I am powering the CC BEC Pro for setting up the system with a 3 cell lipo. I have set the BEC to 6 volts. I am using a JR 9303 Tx in Mode 2 set to one servo. There is no mixing.
The only connections I have on the HC3SX unit is the power and computer link. NO servos are connected, as per the instructions.
Now my problem is the bars on the computer screen are not moving as they should.
Tail is OK.
When I move the Collective pitch stick it's corresponding bar moves correctly but the Aileron bar also moves from max left to max right at the same time. The Aileron bar does not respond to my Aileron stick but the Elevator bar moves instead.
Nothing moves in response to my Elevator stick.
I must be missing something somewhere but at present I am stuffed to know what it is. Any ideas anyone please.
PS I have done a factory reset twice and started again including rebinding the system.
A geriatric flier pushing the brain cells and reaction time.
RC addict with lots of helis, planks and cars.
Last edited by watdazit; 11-09-2011 at 12:33 AM.. Reason: More info added re 1 servo no mixing
watdazit is offline        Reply With Quote
Old 11-09-2011, 03:06 AM   #2
watdazit
I think I have it. I changed the channel assignments in the RC page (plus a few reversals) and it seems to be the answer and everything is moving correctly.
The question now is...did I do the right thing?
Old 11-09-2011, 11:42 AM   #3
Fairview
Yes, you have done it right. You have to map the channel assignments when using spec. sats. Here is another thread you can check http://www.helifreak.com/showthread.php?t=343550
Trex 600n, A610's, Fut.9254, OS50, JR9303
JR Ergo 46, JR4735's, OS46FX
Trex 450P, A410's, A510, Align esc, GP780 gyro, AR6110,
Blade 400, Hitec 65mg's, JR290 w/Fut. 401, stock esc w/Sport Bec, Sonic head and tail
Fairview is offline        Reply With Quote
Old 11-09-2011, 12:56 PM   #4
watdazit
Thanks Fairview. I search the FBL thread and it did not pick anything up and I see that thread is actually under Flight Stabilisation. No excuse though because I had read that thread before and should have remembered.
Old 11-12-2011, 06:17 AM   #5
heli21
Just remember, once you set the bars (reverse for right direction, then sub trim for center, then finally travel adjustment so that they stop on the line before the end of the box) you will not use your transmitter for the swash. You will use the mixer page for reversing servos etc., I have seen guys do this in the past and it will certaintly mess with your head
Rob
heli21 is offline        Reply With Quote
Old 11-13-2011, 09:53 AM   #6
tay.joe75
Default Help for the newbie with DX8 mode 2
Hi there,
I am a complete newbie. I have been on the workstation for 2 days trying to setup my HC3SX. So here is the problem. I finish building my MIni Protos using Stock ESC and motor and now I am trying to setup a DX8 with the helicommand
I have a DX8 on mode 2 .. ie. throttle on the left . First I could not bind the spek sat so I use the receiver to bind it and plug into the HC3SX after. Then on my bars in the diagnose tab it is all funny, I have to keep tweaking the channels for the setup until I get the right bar to move with the right stick and now at the Setup Assistance I have the waiting for ZERO RC signal message. I could not seem to trim or unable to trim anything on my DX8 so that it zero/netural the bar or either that I really don't understand the process. I can move my subtrim but at the moment I can't move forward. As I have 125% on the head channel and 50% on the tail gyro.. sigh. furthermore I can only do a subtrim on my DX8 and when I try to use the trim by holding down the roller and switching on. The Spek sat is not active.. in the DX8 trim mode.. arrrrgh.!
So could someone share your channel assignments for DX8 on mode 2. And is it because I bind the Spek Sat on the original Spek receiver that is causing the problem? I am an absolute newbie..sorry
I thought setting this up will be easy but.. sigh I want to sell it away now Guess helicommand is not good for beginners..!
tay.joe75 is offline        Reply With Quote
Old 11-18-2011, 06:34 PM   #7
heli21
You bind your DX8 and Spek. satalites by using the bind button on the RC Page
The procedure is done the same way but instead of using a bind plug you simply activate bind mode for the satalites through the Helicommand software.
You set the diagnose page once, and only once. Use the method I posted earlier in this thread.
Rob
Old 11-20-2011, 10:38 AM   #8
tay.joe75
Default thanks.. how do i set up the horizon mode
i manage to bind the sat but now how do i assign the horizon gain to my aux 3 on my dx8? So far i assign my gyro using the gear channel and gyro switch. How does the horizon mode works, does it take over the gyro completely? Thanks
Old 11-20-2011, 01:10 PM   #9
heli21
The Horizon mode is controlled through the Rigid gain channel, So before you cannot start working with the Horizon mode you must first get your head gain all set and then select that value for default head gyro gain in the Rigid page.
You can configure your Rigid gain/Horizon channel to AUX 3 by using channel assignment in your radio and setting AUX 3 to channel 7 because that is what the HC uses for Rigid Gain/Horizon for Spek Satalites.
You also should configure the table on the RC page to the channels in your Radio, sometimes they are different.
I would suggest reading the manual front to back before flying, If you have any other questions please feel free to ask.
Rob McQuillen
Helicommand Flight Team
Old 11-21-2011, 01:49 AM   #10
tay.joe75
Hi,
Thanks for your help. I would like to clarify on 2 things.
Ok, so far I set my gyro rate on my DX8 at + 70% and - 70% ( This is set by my vendor who manage to fly on his futaba ) However when I spool up, the heli will tilt to the right just before liftoff. What settings can I change, I have selected horizon mode on norm and inverted
Next I tried to assign the gyro on the transmitter, so far I manage to set my Channel to gear and switch to gyro. What am I missing , I tried to assign the channel of the gyro to AUx3 and when I move the knob, there is no response.. For the switch assignment in the Gyro menu it does not allow me to select Aux 3, it only allows me to choose the generic 3 lever swtich on the top of the transmitter.
Old 11-21-2011, 05:06 AM   #11
tay.joe75
One more question is the swash plate type on my DX8 is 1 servo normal or 120 CCPM. I assume that helicommand does the mixing
Old 11-21-2011, 02:19 PM   #12
heli21
Yes set 50* in your transmitter.
I like to start setting my gain by raising it and doing sharp inputs until it bobbles or shakes. Try it on both axis's. Once it starts to bobble or shake, lower it until it stops. That gives you the highest possible gain which will make your machine feel much more locked in.
Rob
