| 700 Class Nitro Helicopters 700 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
hi guys i have trex700 n and dx8 tx
i want to know how to adjust the headspeed and what is the best for the engine ... my engine is os 91hzr 3d . in idl the temps gos to 220c is that normal or hot ????
Tarot 450/T-rex 600 esp / T-rex 600 esp / T-rex 700 nitro / DX8 ------------------------------------------------ the terx 600 is my toy my hile is t-rex 700 nitro fbl To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
that is hot. are u running using a governor ? ideal headspeed for 700 is 1950
#3 | |
stunt1- 80% stont2- 90%
If at idle your temps go up rich en low and then re tune high and mid . What are you using to control HS ,gov ,limiter etc
i use f mode for gov
#6 |
I'm sure he's right on the 1950, but on the advice of a pro pilot, I bumped mine up to 2000 and it actually runs a little cooler.
700E DFC V3 Quantum 4530, 8917HV,CC120HV,BeastX TREX700LE- 105HZR,Hatori,8917HV,switch-glo/BeastX Synergy E5- Pyro 650 on 10s, 8917HV, CC120, BeastX |
#7 |
you dont need to be in 90% in idl2
if you read the t-rex manual u will see that 80% is the max. today i run my 700 on 82% with DX8. and my engine temp dont cross the 110 celzius / 230f
Dx 8 T-Rex 700NFBL v2 V-Bar Silver Line PRO Ys 120 Full3D |
#8 | |
