| Main Forum - Helicopter Talk R/C Helicopters and the people who fly them. VENDOR TOPICS DO NOT GO HERE. Full Scale Heli threads go in OT please |
Okay. Maybe you expected more because of the title, but once I stacked these up I was pretty impressed. Just 20 x Dell 2650 500 watts. I am building some 24 V rigs for some people here in PR and just received the PSU's today.
FUSION 50 FBL, Scorp HKIII-4025-550/Scorp V 130,610's, V Bar/650 GAUI XB5-EXTREME 12s To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. , Scorp HK-4025-550/CC 80HV, 610's, V Bar/650 AleeS RUSH 750-KDE-700XF-395/YGE160HV, RJX FS0521HV's, IKON/RJX FS0521HV |
Great Ceasar's ghost, what are you doing showing us a picture of all those power supplies, get to work, you have friends in need!
![]() Be sure and post some pictures of the finished product.
Paul Outrage 550 - Castle 3434-1100, Ice 100, Bec Pro, 94758z, Total G w/JR 8900G Outrage 550 - 4020-1390, Ice 100, Bec Pro, JR 8717s, Total G w/JR 8900G Rave Ballistic FSO - HKIII 4035-560, Ice HV160, Bec Pro, JR 8717s, Total G w/BL-9188 |
Here is a pic of the simple version. Just 2 Dell 500 watt PSU's rigged to run in series and taped together. The black connection on the left is for 24V and the one in the middle is for 12V. Red one is either or.
Here is a pic of the set up we ran at our last fun fly. The case is running 2 x dell 2850 poweredgePSU's. 24V 1400watts 57 amps. running a 208b 206b 306b and an accucell 6 and not even hitting its limits or heating up. Not really loaded up in the pic but it got some good use that day.
Do you still have to isolate the ground on one of the Dell PSU's. On the HP ones you had to. Would like to know, if not it would help if i went HP or Dell.
You will have to on any brand from what I understand.
The PowerEdge 2850's that are in the case are a breaze. Two screws are removed and thats it. The Poweredge 2650's that are in the pyramid are not as easy. All I do is remove any screw that grounds the printed circuit board to the case and place a pretty thick piece of plastic between the case and the board. There are usually enough screws laft to hold things together. I then run some epoxy in the screw hole from the outside to make sure the plastic spacers do not move. Thats it.
#6 |
it can also be done by removing the ground wire from one of the power cables, correct? would be the same thing essentially but not as clean I guess.
Compass 7HV, SAB Goblin 700, Minicopter Diabolo, Mikado Logo 600, Synergy E5 RCHeliCanada.com - Compass Model - Synergy - Scorpion - MKS Servos - YGE - Kontronik |
#7 |
correct
Team "Wife" sponsored pilot... Thanks Baby!!! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. AMA# 977810 |
#8 | ||
Hey Michael,
Looking good, you may need to install your own power generating plant at the flying field after making all those power supplies for the guys. tshelby 73 wrote: Quote:
belcom wrote: Quote:
This is the DELL 6650 PSU, it requires no ground mods to run in series. The sticker from one of the 6650s.
#9 |
I have an old Dell tower and an Emachines tower sitting in my garage. Could I do something with the power supplies from them ?
Chris |
#10 | |
Although I've been looking at that Meanwell 1000w supply for a while. What I really like about it is that it's quiet. Ones I have make a ton of noise due to small fans running at high RPM to push the air.
#11 |
Where are you guys getting your server power supply(s)?
Tarot 450 Pro V2 FBL - Still Learning Blade mCP X (BL w/HP-05 S) - My "Sim" Syma S107G - Yellow Toy |
#12 |
I found the HP power supplies via ebay. It was a small local shop so I picked them up for $15 each. Work perfectly but pretty loud though. I chose these because there was a write up and what needs to be done and how.
Here it is: http://sites.google.com/site/tjinguy...projects/HP47A http://sites.google.com/site/tjinguy...ts/diy-24v-47a
#13 |
I did the series mod on a PS. After removing the ground, I made sure to wrap the entire case in duct tape. Then if the supply ever shorts it will be impossible to accidentally come in contact with it.
Rush 750 w/ Xera 4530-500 (12T), YGE160HV, WR S.BEC, Torq 9180/9188, AR7200BX Outrage 550 w/ Scorp 4020-1390 (13T), YGE120, CC BEC Pro, Quark, MKS BLS980, Futaba BLS451 Last Rebuild: 10/15/12 (O550) |
#14 | |
Use a meter to test that the ground is completely removed by setting it to ohms (test the meter... it should have a reading of 1, touch the probes... should go to very close to 0) now put one probe on the ground plug of the PS and one on the case... should NOT change. if the meter drops off, you still have some grounding somewhere.
#15 |
The sticker from one of the 6650s. I use two of these in series to power my PL8. I highly recommend them. No ground issues, and the fans are either load, or temp controlled. So it is very quiet.
Fusion 50 Skookum - Prôtos 500 VBAR - Trex 450 Pro VBAR - DX7 - PL8 |
#16 | |
This removes ac ground, essentially the same as cutting the ground prong off the plug. It's much safer to remove dc ground and leave ac ground intact.
EXI 450 Trex 600e GF |
#17 | |
Isolating the DC ground is not as hard as many think. Much safer. Would you remove the ground off any of your house hold appliances? I wouldnt. I will be posting some pics of the process for these power supplies. These are a PITA compared to others so it should serve as a good tutorial. Power Edge 2650 500watt 41amp. This where I get them. $16.99 for 2 shipped. http://www.ebay.com/itm/270837559949...84.m1438.l2649
#18 |
Excuse me for being stupid, but what is it with the isolated ground. I have two HP Power suppies that I use and have no problems. what problems would I have if the grounds are not isolated or how can I check for this?
Thanks in advance
Is It Time To Fly Again !!! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Trex 600 ESP Trex 550 E Blade 400
#19 |
Are you running those 2 PSU's in series for 24V?
To run in series you have to disconnect a ground on one PS so that when you connect a positive to the negative of the other PS, it doesnt short out. For example: Plug in two identical power supplies. Both cases are grounded to DC and AC current. When you connect PS 1 + to PS 2 -, you have actually shorted out PS 1. The same as if you touched - to +. Now that I think about it, maybe I have this all wrong. I think that is how it works. Damn. Now I am second guessing myself.
#20 |
can't wait to get mine!
-- Outrage Fusion 50 FBL, Outrage 560k motor/CC HV80 ESC, Torq 9180/9188 servos, Skookum 540 -- SAB Goblin 500, Scorpion 4020-1350kv, CC Talon, Skookum 540 Lynx Heli Innovations Team Pilot | Southwest PR RC Crew |
