Old 11-11-2011, 11:06 PM   #1
MarkFlysHelis
Default DTS 700
DTS 700?
Futaba, Thunder Tiger, Scorpion Motors, OS Engines, Rail Blades, Thunder Power Packs, Cool Power fuel.
MarkFlysHelis is offline        Reply With Quote
Old 11-11-2011, 11:39 PM   #2
ChrisH
What's wrong with the bellcranks/push-pull
ChrisH is offline        Reply With Quote
Old 11-12-2011, 12:20 AM   #3
350Z_Al
Originally Posted by MarkFlysHelis View Post
but when will Align make me a direct to swash heli.....tired of looking around!!!!
good night, and good luck!!!!
T-REX 700 with CHP DL Frame set.. Direct to swash problem solved!
What are you drinking? I'm sipping Maker's Mark Bourbon tonight.
Align 450 PRO DFC 4S KDE 450XF // Blade 450X 450MX, 3GX, Savox // Align 450 Sport V2 Airwolf
Align 600EFL PRO, DFC, 3GX, KDE
Align CHP DL 800, XERA 4530LE, ICE160HV, AR7200BX, SB-2271MG, SB-2272SG, KDE, Lynx, 115s
Thunder Power 65C LiPo & JR 12X
350Z_Al is offline        Reply With Quote
Old 11-12-2011, 02:32 AM   #4
Blink 182
Yes it is a few extra parts to put together, but not a problem at all, the bell crank system lasts for a very long time. After crashes/many flights the system is still tight.
(・ω・`) ギルティクラウン
Blink 182 is offline        Reply With Quote
Old 11-12-2011, 07:57 AM   #5
nightflyr
Hey Mark,
You can go another route if you like..
This happens to be an excellent setup, designed and manufactured by someone on Helifreak
nightflyr is online now        Reply With Quote
Old 11-12-2011, 09:25 AM   #6
350Z_Al
^ What frame set is that?
Old 11-12-2011, 09:40 AM   #7
nightflyr
kregan K-Fame set
http://www.helifreak.com/showthread....19#post3378419
Old 11-12-2011, 12:32 PM   #8
wheelyking
WOW...
That is a clean looking setup...
wheelyking is offline        Reply With Quote
Old 11-13-2011, 03:25 PM   #9
stewb
600 though?
stewb is offline        Reply With Quote
Old 11-13-2011, 04:30 PM   #10
nightflyr
yes, but I stretched mine.
Old 11-13-2011, 06:03 PM   #11
MarkFlysHelis
As wicked cool as that is, All that's really needed is the center section to convert it into a DTS.
If he would make that, I'd chop a frame for it!
Old 11-13-2011, 06:31 PM   #12
nightflyr
Shoot him a PM..... Ask if he'll do one up for you
Old 11-13-2011, 11:43 PM   #13
haq0901
Yeah but that head won't handle the high headspeed load of 690-710 blades for sure!
Futaba -TP - Xera - Kontronik - Edge - Insane Canopy
haq0901 is offline        Reply With Quote
Old 11-14-2011, 07:04 AM   #14
nightflyr
Ohhhh The RJX 90/10 head handles the HS with no issues at all
