Go Back   HeliFreak > R/C Electronics Support > HobbyWing ESC's
HobbyWing ESC's HobbyWing ESC Support
Old 11-12-2011, 11:42 AM   #1
mrultralite
Default program box?
I have a platinum pro 70A esc w/ no bec ,instuctions say i need a seperate 4.5-6v bat to power the program box, so now maybe i have to spend$20 on a receiver bat i'm going to use once. Why can't i just use the output from my WR super bec?
mrultralite is online now        Reply With Quote
Old 11-13-2011, 03:09 PM   #2
sjsamuel
I think you can use any power source as long as its less than 6v. I used a regulator on a bench hooked up to a 2S lipo and turned it down to less than 6v. Everything worked fine!
sjsamuel is offline        Reply With Quote
Old 11-14-2011, 03:14 PM   #3
Larry227
I think when I used the box to program mine I used 3xAA batteries in series for 4.5v and it worked fine.
Compass 6HV - SK540 - MKS HBL665/669
Trex 500 ESP - SK540 - 510's/BLS251
DX8 / Phoenix / Persistence
~"See the heli, fly the heli"~
Larry227 is online now        Reply With Quote
Old 11-14-2011, 06:13 PM   #4
jrod155
you can also power through usb and program with your computer
Compass 7HV, El Brute, Ice2 120HV, TracX fbl
Compass Atom 500, Ice 100, TracX fbl
TX: Futaba 7C w/ Fr-Sky DHT, Soon to be Taranis
Old Models: X2, X5, TREX(250, 450, 600ESP), WARP 360, 6HV, 450X, bl CO5M MCPX, Genius CP
jrod155 is offline        Reply With Quote
