| Bantam Bantam e-Station Charger Support Forum |
Wassup all,
I have the TP1010C charger and want to use it at home. So obviously I need to look for a efficient 12-13 Volt, 10-12 Amp AC-DC Power Supply. I noticed that AstroFlight makes one... but can anyone recommend some others to me with brand names included? Thanks!
-jT *Closed mouths don't get fed* Trex 500, Trex 600N, Avant Aurora |
I go the PC power supply route. Here in the S.F. bay area you should have no trouble getting one free. Makes a great supply.
Nothing is ever as good or as bad as it seems. |
I am charging 2 5s (4350 MAH) packs together with seperate TP1010 chanrgers. To do that, I need a hefty power supply. I got this one. As you can see, that item has ended on ebay. I'm sure you can find it eleswhere or something similar.
Search ebay and craigslist for HAM radio power supplies. Those are great because they are 13.8 volts and high output current. jrohland |
You can get this for the starting price. About 1.5 weeks shipping time from China. It's made by MeanWell - a good quality switching power supply
http://cgi.ebay.com/12V-13-8VDC-12-A...mZ230126242413 Dave
_____________________________________ Hmmm, so that's what's on the inside.. . . . . |
Dan Da Dawg - JR X9303 Hexa F550 on 3S + 6S TREX 500 + 6S TREX 600 + Blade mSR + Blade mCPx2 Brushless + 12S Rave FBL ENV |
#6 |
I see these are still on sale too
http://www.circuitspecialists.com/prod.itml/icOid/9099 150W (12V 12.5A) ~$27 This company is in AZ. Dave
#7 |
Jetstream and MFJ make a nice 40 amp switching power supply . I have been using one of each and they work great. These units go for 160 to 210.
Clint Akins |
#8 |
Debiandog, how do you like your superbrain? I am thinking about getting one myself, how mant lipo cell can you charge on it?
Kevin. http://www.helifreak.com/album_mod/upload/66729665148b049df9ae081efdead50f.jpg[/img][/quote] |
#9 | |
I do not charge lipolys on it. Before I had a balancer I puffed a pack on it.
The warning Quote:
I have not tried it with my V-Balancer. Maybe when the Ion is flying again I will do a test charge since each pack burns about the same amount of Ions (dual packs). Have not tried the newer version (989) but hear it is better ![]()
#10 |
what about pro peak? http://grandrc.com/inc/sdetail/78012
good for using (2) TP1010C's?
#11 |
ALSO, how the heck do you connect your alligator clips to the banana posts on most of these power supplies? Any modifications that you guys do? I don't wanna cut my alligators cuz i will charge off my 12V batt.
Right On
#12 |
I cut mine off, but left ~ 3" of wire left on them, then installed banana jacks. If I need to use them I still can.
#13 | |
#14 | ||
Any problems with the Pro Peak so far Davin 5? What charger are you using? I may go down the Pro Peak road if I don't get a MFJ from eBay. Let me know how the PS works out! :mrgreen:
#15 | |
Are banana plugs all standard sized? I may get a Pro Peak.
#16 |
So far the Pro Peak has been great. I'm using it to power a Bantam 902 charger. The Radio Shack one is good too, I just went with Pro Peak cause it's 30 bucks less. Are you in SF? Where do you fly at by the way?
#17 | ||
#18 | ||
Because I soldered banana jacks to my battery clips onto the remaining 3" of wire, I can still use those if I want to by plugging them into my banana plugs on the charger. The 33AH SLA battery has been plenty big for me though. There is a 'mini' banana plug, you don't want that. If it doesn't say 'mini' you should be safe. Some plugs and jacks are better than others. I've been using Pomona and Keystone brand for many years - they hold up well. Dave
#19 |
I went with IOTA 55amp power supply. Enough to power both of my TP 1010c chargers when charging 2 10s packs at the same time and plenty left over for my other smaller chargers too. I've had zero problems with it, and it always on too.
I got it for 135 brand new off ebay. Thanks. |
#20 | |
http://cgi.ebay.com/ws/eBayISAPI.dll...m=260116997633 12V at 125A. I was told they were used for the LED signs around the perimeter of the Atlanta Braves stadium. Overkill for my RC needs but I can see needing them for side business work in the future. Dave
