Go Back   HeliFreak > R/C Helicopter Support > Miniature Aircraft Helicopters > MA Whiplash
MA Whiplash Miniature Aircraft Whiplash Helicopter Support Forum
Old 12-28-2011, 07:44 PM   #21
Avi_Y
The best would be to follow MinAir's instructions from the old kits - instead of fully fastening the parts onto one frame, and then installing the other, lossen the bolts of all the connections between the frames, and only when the second frames is also loosly tied, start fastening all bolts. It eliminates tweaking of the frames, and releases the one way bearing.
Originally Posted by Choppersrc View Post
Same issue.. I can not fix it... trying all your suggestion, but still running hard..
Avi_Y is online now        Reply With Quote
Old 01-02-2012, 02:00 PM   #22
Weez
Default Just fix it
Here is the deal, when you tighten up the sprag cup set screws, the one that sits on the round part of the motor shaft cocks the sprag cup and causes the cup to have excessive runout. The fix is to just lightly snug this set screw and tighten the one that sits on the flat part of the motor shaft then tighten the other set screw. You could also determine your correct sprag height and then set it up on the bench with a dial indicator (I mentioned this in previous post) then install in frames. You may have to fiddle with the lower bearing block a bit too and If the installation is still tight just put at the tightest point and loosen up all of the bolts and retighten (don't forget the two attaching the motor mount to the main shaft bearing block) but I did not need to do this since I dialed out the sprag. Mine had the same problem everyone else is having, It was just unacceptable for me personally.
MA Whiplash Elec FBL, CGY 750, KDE 700XF, CC ICE2 HV160
Weez is offline        Reply With Quote
Old 01-07-2012, 10:20 AM   #23
nwmtech
It is a bit of a bugger to get right but once you get the hang of it it's not that bad. I've swapped numerous motors for testing purposes and now that I've got the feel for it I can get it all tightened down the first time with no dragging at all.
nwmtech is offline        Reply With Quote
Old 03-12-2012, 10:03 PM   #24
GCrazy
Default Suggestion on sprag install
Here is what I found during my whiplash kit assembly. Fit-up is great and the issue I ran into was tied to the motor and how it mounts with four M4 screws. On page 27 & 28 where you install the motor/mount with lower bearing support and mate up the body frames, I noticed that three M3 screws for the lower bearing support did not line up. With everything else fitting up so well, I was confinced that there had to be a reason for this mis-alignment. I eventually traced the issue back to the Sprag Cup. On page 25 the manual directs one to push the sprag cup down the motor shaft until it bottoms out. Doing this forced the cup onto two motor mount bolts (see attached picture) which I proceeded to dremel down to assure proper clearance. Result - Everything lined up perfectly without further issue. This might also address some of the free spooling issues others have had - if of course your motor mounts similar to mine with the same bolting pattern. Hopes this helps someone out there.
Name:	Motor mount.jpg
GCrazy is offline        Reply With Quote
Old 07-10-2012, 04:39 AM   #25
kevinbj
Default v-bar help
hey fellas I'm building my first whiplash.. I wanted to know to get the fbl system to work & having ritght for the v-bar do i need to get the 8mm ball part# MA 0109? would y'all care to share v-bar file for the Whip this is my email you can post it there.. thanks
kevinbj@comcast.net
kevinbj is offline        Reply With Quote
Old 07-22-2012, 09:46 PM   #26
kevinbj
I'm getting a ringing kind of noise I jus built the Heli & only have bout 4 flights on it.. It almost sound like a engine from nitro .. The ringing sound.. Any suggestions?
Old 07-23-2012, 10:29 AM   #27
kumar2494
after a while, the sprag will break in and spin freely. it just takes time
SAB Goblin 500
MA Whiplash Electric - 14S
kumar2494 is offline        Reply With Quote
Old 07-23-2012, 11:17 AM   #28
frito169
Default wrong way
This issue is because you're going the wrong way with the sprag cup. When the Heli motor is mounted you're supposed to push the sprag cup down away from the motor till it hits not towards the motor.
frito169 is offline        Reply With Quote
Old 07-23-2012, 11:19 AM   #29
frito169
Default shavings
I hope unlike the other guy you didn't push your Sprag cup towards the motor because then it would be rubbing on those bolts and that is the wrong way.
Old 07-23-2012, 11:42 AM   #30
kevinbj
It is clear from the bolts but I did have it pushed toward the motor .. Today I will push it down the shaft .. Thanks hope this work
Old 07-24-2012, 09:52 AM   #31
kevinbj
Nope still didn't work.. Man this is bugging me
Old 07-25-2012, 12:19 AM   #32
frito169
Default sprag
Have you oiled/lubed the sprag?
Old 07-25-2012, 06:54 AM   #33
kevinbj
I did last nite so I'm going to test it out today after work.. With tri flow
Old 08-02-2012, 02:30 PM   #34
Mike Fortin
EPIC Helis
Kevin, let us know your results.
______________________________
Mike Fortin
www.EPICHelis.com
Mike Fortin is offline        Reply With Quote
Old 08-02-2012, 08:41 PM   #35
kevinbj
Got everything solved.. Thank to all the help from the H.O.D funfly .. It was lik 6 or More whips there we had to get more throw on tail & the ringing noise is jus the mesh.. All made same sound.
Old 09-13-2012, 12:49 AM   #36
gadawg58
My Sprag bearing has finally broken in and spins fine now after 100 flights!
George
XXtreme 800, e Whiplash, TREX 700e V2, TREX 600 Nitro LE, TREX 600 e Pro, TREX 500, TREX 450 Pro, Raptor 90 SE, Raptor 50 V2 ... Some with duplicates
gadawg58 is offline        Reply With Quote
