Go Back   HeliFreak > R/C Helicopter Support > Miniature Aircraft Helicopters > MA Whiplash
MA Whiplash Miniature Aircraft Whiplash Helicopter Support Forum
Old 11-14-2011, 03:46 PM   #1
MichiganFlyer
Default Whiplash Pinions?
Is a 12 tooth going to be available? my 4035-560 would be alot happier.
MichiganFlyer is offline        Reply With Quote
Old 11-14-2011, 04:33 PM   #2
MichiganFlyer
Never mind I did the math, 13, 14 and 15 are what are going top be available.
Old 04-19-2012, 09:55 PM   #3
gadawg58
Did you ever change out the pinion? I am running the 560 as well as am curious. Also, did you ever notice any issues with the stock setup with the 560?Thanks!
George
XXtreme 800, e Whiplash, TREX 700e V2, TREX 600 Nitro LE, TREX 600 e Pro, TREX 500, TREX 450 Pro, Raptor 90 SE, Raptor 50 V2 ... Some with duplicates
gadawg58 is offline        Reply With Quote
Old 04-20-2012, 12:07 AM   #4
frito169
Default 560
I run mine with the stock pinion and an X era 560 kV motor and I run it at 2400 RPMs it runs excellent
frito169 is offline        Reply With Quote
Old 04-20-2012, 08:34 AM   #5
gadawg58
Just curious ... how much pitch are you running. I set mine up with a max pitch of +- 14 and if I give it full collective up or down the tail blows out but only on full collective. Just guessing too much pitch with that head speed and 710's? Also...using the AR7200BX and other than the tail issue flies wonderful!
George
Old 04-20-2012, 09:25 AM   #6
frito169
Default tail precomp
I run 13 degrees of pitch. Even with that heavy pitch pump I get no tail movements are you sure you have your precomp set in the correct direction or is it even on?. My whiplash has super tail authority I can't imagine it ever blowing out I to have the beast X a R 7200 BX as well.
Old 04-20-2012, 09:26 AM   #7
frito169
Default tail blades
What size tail blades are you running I have run both 105 and 95 and both hold excellent.
Old 04-20-2012, 10:43 AM   #8
gadawg58
I have the Rail 106's. Also precomp is not turned on .. I'll give that a shot this weekend.
Thanks!
George
Old 04-23-2012, 08:32 PM   #9
shein95
So what is the general consensus on head speed on the whiplash? I haven't gotten one yet but was looking at motors for one using Mr Mel's head speed calculator and to get even a 500kv to work with stock gearing seems to put it in the 2200-2400 range which blows my mind for a 700 since I'm currently running 2250-2300 on my 550 with 553 blades. I've only seem this bird in person once and looks beast so sure it can handle high hs but wanted to make sure I'm on right track before buying a motor.
Trex 450pro FBL Mini V Bar, YGE 60, scorpion 2221-8
Trex 550V2 FBL V Bar, YGE 100, kde 600xf-1100
mCPx 2
Trex 700e dfc hv V Bar silver line, CC Ice2 120hv
shein95 is offline        Reply With Quote
Old 04-23-2012, 08:38 PM   #10
HeathH
With 710 blades, I have settled in on 2000rpm. Anymore is just a waste imop.
I like helicopters
HeathH is online now        Reply With Quote
Old 04-24-2012, 07:52 AM   #11
gadawg58
Turned on tail precomp this past weekend and that fixed the tail issue completely. Running 2400 RPM with the Scorpion 4035-560. What a beast! :-)
George
Old 04-24-2012, 09:32 AM   #12
frito169
Default good to hear
Sounds great glad you got it figured out. Good luck you'll love this machine.
Old 06-20-2012, 02:41 PM   #13
submissive air
What pinion are you using? Gadawg58
submissive air is offline        Reply With Quote
Old 06-21-2012, 06:19 PM   #14
gadawg58
I am running the stock pinion that comes with the kit. I have also swapped out the motor to the 4525-520 Ultimate and what a difference. I think the stock pinion and the 560 aren't as good a match as the 520-530 kv motor. The extra power with the Ultimate helps also! Spinning the head at 2400 solid with this combination. Have gone as high as 2500 and it worked just a little nervous about tail gear etc. Also once you start getting that high the flight times decrease but it is fun!
George
