Go Back   HeliFreak > R/C Helicopter Support > Miniature Aircraft Helicopters > MA Gas
MA Gas Miniature Aircraft Gas Helicopter Support Forum
Old 12-14-2004, 10:06 PM   #1
Dale W
Default Spectra G with the Tempest Head
Well, I've got it together, but now have to wait for a carb changeout. I had a 677 carb on my G231 and wanted the 643. Nathan at Rick's was super helpful and had to get involved with Horizon Hobby to make the swap happen. I should get it in a day or so... I guess that's ok as the weather is turning crappy and I wouldn't be able to put it in the air anyway (I'm not as brave as John!).
The build went pretty straight-foreward, however using JR servos and a Multiplex receiver required a little different setup than in the instructions. I'll take a shot at doing the paint scheme on the canopy. I'm hoping it will be on the wild side.
Anyway, here are some pics.
Dale Wilkins
dwilkins2@cfl.rr.com
Dale W is offline        Reply With Quote
Old 12-14-2004, 10:26 PM   #2
whirlyspud
It looks nice. :mrgreen:
Mike
whirlyspud is offline        Reply With Quote
Old 12-15-2004, 08:09 AM   #3
bigrcr
Excellent, a very nice job! You will love it.
Later
BIGRCR- John Garst
Toxic Racing Motors
IRCHA #1716
bigrcr is offline        Reply With Quote
Old 12-15-2004, 08:16 AM   #4
WillJames
Registered User
Sweet!!!
William James
WillJames is offline        Reply With Quote
Old 12-15-2004, 02:27 PM   #5
dperry
Why would you want one carb over the other?
Don Perry
www.rnlinc.com
dperry is offline        Reply With Quote
Old 12-15-2004, 05:07 PM   #6
bigrcr
The 677 is a POS and is not suitable for operating a gas motor. If you've got one get rid of it and get a 603, 643, 644 or 645. I have several postings about getting one for $35 shipped.
BIGRCR- John Garst
Toxic Racing Motors
IRCHA #1716
Old 12-15-2004, 06:42 PM   #7
Joe Ubaldo
Beautiful bird
Mine shipped from the retailer today. I hope to have it built in time to sit next to the Christmas tree!
Let us know how she flies!
Joe Ubaldo is offline        Reply With Quote
Old 12-16-2004, 05:17 PM   #8
Yellow Spectra
Does the kit come with the servo bridges as shown on Dale's finished Spectra G?
Spectra G w/ Tempest Head
Toxic Racing Motor 231
SAB 710mm white blades
SAB 106mm black blades
Stator Gator
Futaba 9ZH WC2 Radio
Futaba GY601 Gyro
Futaba Digital 9255 Servos
Yellow Spectra is offline        Reply With Quote
Old 12-16-2004, 05:32 PM   #9
WillJames
Registered User
Nope they are addon Part Numbers are #115-87-Futaba, #115-88-JR
William James
Old 12-16-2004, 08:31 PM   #10
Dale W
Well, my 643 carb hasn't shown up yet, but tomorrow I'll be going to pick up my 644 carb from Alan. This carb, as he describes it, is just like the 643, but adds a choke. So, if you were to run an aftermarket air filter, like the K&N shown on the prototype/box, you would either need a carb with a choke or put up with some funky cold starting techniques! The choke in the stock motor is in the air filter.
So, the 643 carb is the recommended carb fo my stock G231 engine & has a primer bulb but no choke, the 644 adds the choke and the 645 doesn't have a bulb.
Dale
Dale Wilkins
Old 12-17-2004, 01:41 AM   #11
Yellow Spectra
so which carb recommendation? 644 or 645?
Stator Gator
Futaba GY601 Gyro
Old 12-17-2004, 02:28 AM   #12
WillJames
Registered User
I would go with the 644 just for the choke. I have a 645 now and as long as I don't go to an air filter I can easily choke it with my finger.
William James
Old 12-17-2004, 08:12 AM   #13
bigrcr
Any of the three 643, 644 or 645 will do just fine. They are the same other than the primer bulb/choke. I personally don't like the choke plate in the carb, it get's in the way. I took Wills off of his carb (a 645).
643- primer bulb, no choke (choke in air filter box).
644- primer bulb and choke in carb body.
645- no primer bulb, choke in carb body.
any of the carbs will support the primer bulb if installed.
I have found choking totally unnecessary.
Hope this helps!
BIGRCR- John Garst
Toxic Racing Motors
IRCHA #1716
Old 12-20-2004, 08:38 PM   #14
Flyjet747
Default Spectra G
Wow that is a spectacle to gaze at for hours. It's a beautiful looking machine. My friend just ordered one. He should have it by end of the week. Can't wait to see it.
Flyjet747 is offline        Reply With Quote
Old 12-20-2004, 11:13 PM   #15
Kevin22
hate to sound like an idiot but what is a servo bridge? Is it needed only for JR servos? Thanks for any replies
Kevin22 is offline        Reply With Quote
Old 12-21-2004, 02:54 AM   #16
WillJames
Registered User
This is a custom made servo support (bridge) made by Ron Darling for a Raptor 90, but you get the idea. I did not have a closeup of a MA one on hand, sorry. I don't think the brand of servo you are using matter, bu tI may be wrong. I run Futaba. From what I understand they help keep slop from developing in your servo output gear by relieving the side loads. (I may be wrong about that to, so please correct me somebody)
William James
Old 12-21-2004, 07:54 AM   #17
Dale W
Look at the second and 4th pictures of the Spectra above. The little CF piece that seems to cut across the servo disk is the bridge. The servo arm screw is replaced by a post that screws in and the CF bridge has a bearing that this post slides into. The whole bridge is kept just above the servo arm by standoffs and the appropriate length screws. MA has PEM nuts sunk into the Fury frames to accept these additional screws. The bridge helps keep the servo push/pull straight as Baja170 says and also keeps the arm on the output shaft, as there is no way the arm can work itself loose and fall off... (I've never had that happen on any heli though).
Dale
Dale Wilkins
Old 12-21-2004, 12:42 PM   #18
Kevin22
thanks for the info
