Go Back   HeliFreak > R/C Helicopter Support > 550 Class Electric Helicopters
550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 11-15-2011, 05:10 PM   #1
Montana
Default I feel like a noob all over again
I've been crashing my 450 Sport for about two years now (some flying, too) and I can rebuild it with my eyes closed. But I've decided to build a 550 FBL this winter so I've been doing my research on this forum. My head is swimming! I feel like a noob all over again. Sometimes I think I'll never be able to get this thing off the ground, but then I remember I felt the same way with the 450 and that turned out ok. Eventually.
Anyway, just introducing myself and thanking everyone in advance for all the help I'm going to need.
Montana is offline        Reply With Quote
Old 11-15-2011, 05:29 PM   #2
thanasi
Gidy Up mine is under the Christmas tree
Cant sleep at night !
Dx7,T-550Ev2,T-450 pro Dfc, 130 X, mcpX BL
Brushless Nano
RUSH 750 being built
thanasi is online now        Reply With Quote
Old 11-15-2011, 05:53 PM   #3
Montana
Wife says since it's a winter project I can't start until Winter i.e., December 21.
Old 11-15-2011, 07:02 PM   #4
Wolfpackin
Good luck with the build.
You'll definitely want to be doing more flying than crashing with the 550E.
Unless you have deep pockets $$$.
Zen and the Art of Helicopter Maintenance
Blade 400: E-flite 420H/35X ESC, AR6100e, HS65HB x 3, G401B/DS290G. (Ret.)
CopterX 450AE V2: 430XL/35X ESC, AR6100, HS65HB x 3, LTG2100T/HSG-5084MG.
T-Rex 550E V1 Classic Flybar: 600MX/BL70G, AR6200, DS610 x 3, Quark/DS650, 16t/520mm blades.
Wolfpackin is online now        Reply With Quote
Old 11-15-2011, 08:19 PM   #5
garyji
You're going to love it!! Keep us posted. Don't be afraid to ask any questions you can't find the answer to.
G.
T-450 Sport FBL, T-550 V1 FBL, T-600E Pro. Red Goblin 700. Tarot Pro 450 in a scale Hughes. Bunch of little Blades, and Planks. DX8, Full scale Jet Plank Driver.
garyji is offline        Reply With Quote
Old 11-15-2011, 08:27 PM   #6
Tenguru
It's much easier to fly a 550 than a 450. I think you will really enjoy it.
Tenguru is offline        Reply With Quote
Old 11-15-2011, 08:37 PM   #7
bike mad
I wouldn't worry, I used to crash my 450s all the time, the mix of very cheap parts that I kept in stock and a quick rebuild time meant I didn't mind risking it and by pushing my self I leant faster,
I find the 550/3G easy to fly and don't risk it in the same way,It's hard to put into words never mind expain why, all I can say is I wished I got a 550/3G much sooner than I did, yes it costs a lot more when you crash (manly blades) but you crash less so it's not as bad as you first think, is it worth it ? OOOOO yes,
bike mad is offline        Reply With Quote
Old 11-17-2011, 09:00 AM   #8
markleyland
Happy Dayz! You are going to luv it!
"Sort your head out and fly with your heart"
Trex 450 SE V2: 9257 tail, Spartan Quark, HS65mg cyclic, DX7-AR7000, NEU 1107h/2y, Jazz Esc,
Trex 550 FBL: Jive 100+LV, KDE/NEU 1907H/1/N42, Vbar 5.3, Futaba BLS 251
markleyland is offline        Reply With Quote
Old 11-17-2011, 09:47 AM   #9
Montana
Old 11-17-2011, 10:48 AM   #10
Raptorg2zman
I've been flying my 550e 3g bone stock since last April. I love the thing. My flying has really progessed with it since I started to fly it. I find it much easier to fly then my 450 & easier then my 500. So much so that they really haven't seen the air since I bought it. Even though I don't push myself as hard with it, because of it's better inherant stability, everything is easier for me, really hard to explain. Get one & you won't be sorry.
Jimmy R
SE Mass
Trex 450 / HK pro ,500esp, & 550e FBL
Blade MSR
Raptorg2zman is offline        Reply With Quote
Old 11-17-2011, 10:58 AM   #11
Montana
The turning point came for me when I put Helicommand on the 450s, gained confidence in the Helicommand and the heli, and started flying higher and farther away. Then I was able to start "flying" instead of "hovering and drifting around". But flying farther away it became harder to see the heli, hence the 550.
I'm putting a Skookum on the 550, so hopefully it will have the same sort of self-leveling stability as the Helicommands.
Thanks to all for the encouragement and well-wishes. I can hardly wait to get started.
