| Hurricane 550 Discussion and support of the Gaui Hurricane 550 |
Following nearly selling my 425 and deciding to stretch it to a 550, with great advice (thanks mikej!!) ordered 2 trex 550 canopies which arrived today
I am blown away with the price and the quality...$33 delivered for 2!! this is my favourite.....
Blade mCPx, Align Trex 250, Align Trex 500, Gaui 550 Hurricane, HK600GT H.A.L. Quadcopter I have a perfect record in helicopter flight......I've never left one up there!!!!! |
lookin' good
have you re-maidened yet ? |
Really pleased with it!!
Not maidened her yet..... new OWBs arrived but been waiting for front gear collar and decided that I'm going to tidy wiring and do a proper job Hopefully give her a try this weekend
Good stuff - hope maiden goes well
So do TREX550 canopy's fit straight onto a GAUI550? as ive been thinking about giving my GAUI a make over
Walkera 4F180, Walkera LM3, ESKY CP3, ESKY HBK2 3 Blade, ESKY Belt-CP, HK450, CopterX500, HK500GT, GAUI550, HK C30 Gyroplane, others To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#6 |
...Yes, they do...very minor trimming on top and some use 600 canopy mounts(Wider)
I use stock canopy mounting...
Gaui 500 / Tarot Quad 450 KK2.0LCD/ X525 (2X) DC 450 FPV 500mw 5.8 / SC10 AMA 953414 |
#7 |
PT!! almost same as my no 2 canopy!!
http://www.hobbyking.com/hobbyking/s..._rex_550E.html I too use standard mounts on mine
#8 |
Yep...got this one from Hobbypartzdotcom....9.00 dollars I think
PT
#9 |
how did you guys get them to fit.Mine with a 6s battery has a big gap between bottom of canopy and main frame.probably about 2 inches or more
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. MAAA membership AUS71789 B400 gy401 s9257 tail servo HS 65 mg servos this thing rocks |
#10 |
where the standard canno mounts on that little black thing at the bottom to hold it in place .Mine wont even get close.Am I missing something.
#11 |
On my 550, I made my own bottom pin from a std. servo horn(DS821 Servo)
The pin is an old worn out ball link, squished to make it "even" and place a short piece of fuel tubing to "Cushion" the canopy. The distance from where the pin to the mount C/L is 1.5 " I WAS using the 600 upper mount shafts, but have since put the stock ones back on and use those even withe larger 550 canopy or the stock F/G Canopies. The largest Batt I have is a 3000mAh 6s 30c and has to be mounted under the chin cut out ( no angle piece) My 500 bladed mid boom has the angle piece on the bottom for when I use 2-3s batts...but don't normmaly run the big 550 canopy on it...looks screwy! PT
#12 |
#13 |
...Looking Good!
I want to try the Blue color on one of mine too! PT
#14 |
I think I should of made them bigger lol.
#15 |
