Old 11-17-2011, 08:54 PM   #1
Youthanasia
Default I2 RC FB500A-Pro Performance Head
Anyone out there using this head on a 500E Pro??? I emailed Bob to see if it fits the Pro and he said it should but he didn't test it on one yet.He can make adjustments on it if needed.
I would have to use the stock bearing blocks as his will not fit,he is working on a set for the Pro but won't be done for a couple weeks.
Maybe the KDE bearing blocks would work with that head
Youthanasia is online now        Reply With Quote
Old 11-17-2011, 10:58 PM   #2
flerpie
Quality is worth waiting for
HK Best Of Custom 450s & 500
Build Different!
flerpie is offline        Reply With Quote
Old 11-17-2011, 11:17 PM   #3
growmaster4
They will be worth the wait,and bob will for sure get the head fitting for you,he helped me out to get one mounted on a compass atom,worked out great.
Trex 500 12s vbar I2 bling
Furion 600 12s vbar I2 bling
trex 700edl vbar 12s I2 bling
Tdrex 800e 12s vbar I2 bling
Bank account EMPTY
growmaster4 is offline        Reply With Quote
Old 11-18-2011, 08:43 AM   #4
skered53
brg block probably narrower , i bought a set of frame braces ( those tubes) ws going to put one under the main gear ) anyhow the 500 pro ones were about 2 to 3 mm narrow.
T-rex 500FBL BeastX, I2 MRH & Swash, I2 tailboom holder TT version,( Bob's the Mahn ! ) DX7s. Gaui 550 FB, T-rex 550 I2 FBL head.
CH-53E's 83-87. MCAS New River. FAA certified Airframe & Powerplant license holder since 1992
skered53 is offline        Reply With Quote
