Go Back   HeliFreak > R/C Helicopter Support > Walkera Helicopters
Walkera Helicopters Walkera Helicopter Support
Old 11-18-2011, 08:17 AM   #1
dragonflyer
Default Lipo battery for WK 2801 Pro transmitter?
The power source for the WK2800 pro is 8 x 1.2V (NiCad) or 1.5V (dry) batteries. (9.6V-12V)
and the current drain is 120mA@10mW or 230mA@100mW.
My question: Can I use 3 cells of LiPo 340mAh batteries for this transmitter?
Specifications:
Battery Type: Lithium Polymer
Typ. Capacity: 340 mAh
Nominal Voltage: 3.7 V
Height: 2.6 mm
Length: 41.2 mm
Width: 34 mm
Weight: 8 g
Number of Cells: 1
Wire: 11mm
Note: PCM, 11mm wires
Note: I can buy these batteries (3.7V/370 mAH) at a local surplus store for $1.00/each.
Thanks.
What is the problem? What causes the problem? How do we solve the problem?
dragonflyer is offline        Reply With Quote
Old 11-18-2011, 09:07 AM   #2
crf69
i run a 3 cell 500mah turnigy 11.1v lipowith the cells at 3.80v each.
i believe 7.6v is the default alarm voltage for the 2801
crf69 is offline        Reply With Quote
Old 11-18-2011, 03:50 PM   #3
stevec
I got a 2500mah 3 cell from hobbyking. It lasts months.
Cheers
Steve
Futaba 8FGS,Dx6.
blade Nano, Blade 450x, Blade 180Cfx, Trex 250DFC pro, Raptor 90 SE Gasser.
various Quads.
stevec is offline        Reply With Quote
Old 11-18-2011, 05:30 PM   #4
krobinson103
Running a 850mah 11.1v trex 450 flight pack. Its good for about 10 hours until it hits about 11v. Plug and play replacement. Remember to set the low volatage cutoff to 10.8v so you don't toast the battery if you forget to turn of the tx.
krobinson103 is offline        Reply With Quote
Old 11-18-2011, 09:17 PM   #5
crf69
im confused on that last sentence.
Old 11-18-2011, 09:33 PM   #6
krobinson103
The tx of=off...
Old 11-18-2011, 10:33 PM   #7
crf69
oh shoot......ok gotcha
Old 11-19-2011, 12:25 AM   #8
etopsflight
Guys
This info is useful as I want to use Lipos in my Walkera WK-2801 Pro instead on normal AA cells.
Cheers
Etopsflight
etopsflight is offline        Reply With Quote
Old 11-19-2011, 05:31 AM   #9
stevec
Here is what I am running.
http://www.hobbyking.com/hobbyking/s...utaba_JR_.html
Works a treat just one problem I have noticed and that is I need to check the mode the handset is in after disconnecting it. I now charge it in the tx connected...through the balance taps
Cheers
Steve
Futaba 8FGS,Dx6.
various Quads.
Old 12-08-2011, 03:10 PM   #10
TaterTot
Cheers
Steve
Did you have to add a connector to that Lipo in your link?
I know that the 2801pro uses a standard JST connector for the battery pack, but the one in your link does not look like it comes with a JST connector...
DJI F550 E300 w/ Naza-M v2 - Build in Progress
Tarot 450 Pro V2 FBL - Still Learning
Blade mCP X (BL w/HP-05 S) - My "Sim"
Syma S107G - Yellow Toy
TaterTot is offline        Reply With Quote
Old 12-08-2011, 03:41 PM   #11
stevec
Hello,
Yes I swapped out the main plug for one that matched the socket on the tx. I can't remember what type it is... The red connector which is roughly 10mm long and 5mm wide...
I simply cut the connector off of something I had laying about they are easy to get from electronics shops.
/Steve
Futaba 8FGS,Dx6.
various Quads.
Old 12-08-2011, 03:49 PM   #12
crf69
it's a JST connector
Old 12-08-2011, 04:00 PM   #13
stevec
Ok Jst I just chopped off whatever it came with and soldered a Jst on.
Futaba 8FGS,Dx6.
various Quads.
Old 12-14-2011, 07:56 AM   #14
dragonflyer
I found and bought this one on eBay today:
http://www.ebay.ca/itm/310349730247?...ht_2581wt_1016
Old 12-14-2011, 10:36 AM   #15
crf69
my 11.1v 500mah turnigy pack lasts about 15 flights till it gets to 11.5 and 3.85 per cell.
perfect for me.
Old 12-14-2011, 01:08 PM   #16
dragonflyer
perfect for me.
Good info, sounds even better for an $11.00, 2200mAh, 10C battery!
Old 12-22-2011, 05:17 PM   #17
czynot
Any danger keeping Lipo in the radio?
I dont fly everyday. Do i need to keep the radio lipo in storage? its a PITA to remember to keep radio battery in storage and remember to charge it before flight. I feel like taking it out of my radio.
czynot is offline        Reply With Quote
Old 12-22-2011, 05:27 PM   #18
crf69
yeah keep it at 3.80 per cell.....dont leave it in charged obviously as thats bad for lipo as im sure you well know.
i chain fly like today i flew 9 packs through Genius and 10 packs through V450D01. My turnigy 11.1 500 mah battery went down to 11.3 3.76per cell.
if you fly only a few packs a day i would just use AA's.
leaving it in the TX at storage level shouldnt be a problem either.Unless it spontaneously self combusted
Old 12-23-2011, 02:56 AM   #19
stevec
I have a lipo in mine, I use it maybe 3 times a year, always sitting at the correct voltage and no issues for me so far.
I think it has only been charged 3 times in its life.
with the low discharge rates of the application I am not worried about the problems associated with high internal resistance arising from leaving fully charged.
the lipo in mine is at least 2 years old.
cheers
Steve
Futaba 8FGS,Dx6.
various Quads.
