Old 11-20-2011, 11:58 PM   #1
theatreheli
Default Biggest Landing gear?
I want to give my 450 sport a lift, what the biggest gear I can fit on without modding the gear? 550?
-Alex
Blade mCP X | TRex 450 sport
DX6i
"As with all flights: taking off is optional...but landing is mandatory" -Adam Savage
theatreheli is offline        Reply With Quote
Old 11-21-2011, 07:20 AM   #2
srt4tom
500 will make your heli gain a little wieght, but any bigger and it'll become just plain fat, unless you find some that is CF.
srt4tom is offline        Reply With Quote
Old 11-21-2011, 01:10 PM   #3
Corvette & Copter Guy
-Alex
I have Align 500 gear on mine and you WILL have to drill new holes with ANY bigger gear. On my Furion 6 I run Quick UK gear and I love the size compared to stock.
FURION 450 FBL: BEAST-X, CANOMOD, HW, KBDD, POWER HD, SCORPION
SYNERGY E5: BL9180/9188HV, CC 120HV, KBDD, RAIL, SCORPION, V-BAR
LOGO XXTREME 800: EDGE, MKS 950/980HV, SCORPION, V-BAR, YGE 160HV
DX18, PL8, PHOENIX SIM, SEVERAL PLANKS
Corvette & Copter Guy is offline        Reply With Quote
Old 11-21-2011, 02:08 PM   #4
Luvmyhelis
500 gear will work just fine as it provides a full 2 1/2 inches of ground clearance and they are roughly 7 inches wide. However the largest set of skids is the T600 set. I use them for deep grass flying and I cut down the skid tubes. In one I use CF skid tubes and the CF skids from HK. The CF skid tube needs to be 9mm to work. Personally I have never found a need to have the skids bend at the forward tip for grass flying.
http://www.hobbyking.com/hobbyking/s...elicopter.html
Looks nice and they are super light. I have never lost a tail since upgrading to them, nor had a landing where the heli tipped since they are roughly 9 inches wide. All the parks and schools I fly at locally seem to have unseen dips in the grass that you cannot see until touchdown.
I had way too many tip overs with the stock gear and tail issues grinding into the grass. Also the 500 skids have weak skid tubes. I was constantly bending them. But they do look better and more symmetrical than the 600s. But the 600s are tank tough.
Luvmyhelis is offline        Reply With Quote
Old 11-21-2011, 02:39 PM   #5
NCcraig
I have the landing gear off my 500 and a Fusuno 500 vertical tail on my 450. I kinda like it and it keeps the tail rotors out of the grass during the Summer months.
Craig
Team Newb pilot
MCPx brushless conversion (HP06V2 motor/HP03 tail),Trex 450 Pro V2 (KDE450XF motor,iKON),Trex 500 ESP (KDE500XF motor, iKON),DX7, AMA# 966513.
PM me about mCPX & NanoCPX BL conversions.
NCcraig is offline        Reply With Quote
Old 11-21-2011, 04:38 PM   #6
salrica
I bought several months ago metal landing gears and they looked so good on the heli.
But, if for some reason you have a motor failure or a hard landing, you better order a new set of frames and bottom plate.
After that I throw'em away.
Don't get the rigid ones, you want some "spring" on'em.
Go for the Align 500
salrica is offline        Reply With Quote
Old 11-22-2011, 09:45 AM   #7
Montana
I've had the plastic baseplate fail on me twice with oversize gear. The result is dramatic (think mid-air explosion). Since then I've used aluminum baseplates. The oversize gear tends to amplify or resonate with vibration.
Montana is online now        Reply With Quote
Old 11-22-2011, 01:48 PM   #8
Luvmyhelis
The align plastic baseplates are pure cheap trash. Mine were cracking out at the rear junction repeatedly even doing mild basic break in flights. I had to go to the aluminum baseplate. Plus the plastic versions were simply warped and off level. I couldn't successfully mount my gyros, nor my Sk720 inside. I even had the plastic baseplates crack out in my scale versions. I eliminated those harmonic vibes in two different ways. First was to shorten the skid tubes. Next, I had to realize that Trex makes a vibrating sloppy heli to start with. So I had to address each of those issues to calm mine down. It is not just a skid size issue. They only act according to what they are mounted on. No vibes, no resonating.
Old 11-22-2011, 02:01 PM   #9
The Quick Uk landing gear (for the 600's) is larger than the T600 gear. The skid pipe is also far larger in diameter.
Check them out.
