Go Back   HeliFreak > R/C Helicopter Support > 700 Class Nitro Helicopters
700 Class Nitro Helicopters 700 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 11-25-2011, 05:20 PM   #1
ualdrivr
Thumbs up A very nice and worthy Lynx upgrade!!
Just like to drop you guys some knowledge....
I just purchased the Lynx Main Bearing block upgrade, http://grandrc.com/Nitro-Helis-&-Par...duct_info.html
http://www.lynxheli.com/product_info...ducts_id=22153
What a worthy upgrade. The biggest plus of the upgrade is the easy on and off that this clutch bearing block provides. No more need to try to pull the frames apart in order to get the clutch bearing block/bell stack out of the heli. You can change the bearings and inspect the clutch liner and start shaft as easy as 1,2,3.
Here is some pics:
Enjoy!
Name:	Lynx Bearing Bolck 01.jpg
ID:	269060   Click image for larger version
Name:	Lynx Bearing Block 02.jpg
ID:	269061   Click image for larger version
Name:	Lynx Bearing Block installed.jpg
At the precipice, we change!
Team GrandRC
ualdrivr is offline        Reply With Quote
Old 11-25-2011, 05:49 PM   #2
backburner1955
That's nice. I may look into that.
AMA# 982814
backburner1955 is online now        Reply With Quote
Old 11-25-2011, 06:33 PM   #3
ualdrivr
Bryan, it makes life soooo much easier. I was skeptical too, then I went for it and OMG, how sweet it is..., to get the main bearing block out with no fuss or muss.... Heli-Copteron is been telling me about and he loves it too.
Team GrandRC
Old 11-25-2011, 08:35 PM   #4
FlyinHigh1
Ive been running that since my 700 was new.I didnt like the stock set....and grand had it listed and gave it a whirl.ITS SWEET. Just pop the links out of the way,move align sensor,and the six screws and the whole stack slides out. It was very useful when the start shaft/bearing slipped and got right to it for maintenance.I can even change the clutch without eng. removel .AND it looks cool too!
Trex450proGT-T REX 700N LE/ALIGN 91H/OUTRAGE HYPER/FUTABA FASST/GRYPHON/LYNX GALORE
FlyinHigh1 is offline        Reply With Quote
Old 11-26-2011, 05:05 PM   #5
Felt
+1 Thanks for the review. Certainly sounds like a worthy upgrade.
Felt is offline        Reply With Quote
Old 11-26-2011, 11:42 PM   #6
Chris Lalonde
I just ordered this unit the other day along with there HD clutch. Can't wait for it to get here
The one I ordered looks a little different though
http://www.rotorquest.com/product_in...ducts_id=13437
Chris Lalonde is offline        Reply With Quote
Old 11-27-2011, 07:42 AM   #7
FlyinHigh1
Im thinkin its just a bad pic.The Lynx one I have doesnt have pins in between the frame screws like the align units.It comes with Lynx cone type stainless screws and is threaded there.
Old 11-27-2011, 09:15 AM   #8
ualdrivr
Chis the one you ordered is actually the older version of the Lynx bearing block. The previous version had the little notches like the Align has to snap into the frame's slots and you could adjust it back and forth a bit to fine tune the gear back-lash, or that was the idea anyway. See if they have the newer version at that place where you ordered it.
On another note, I would not recommend using the Lynx clutch bearing block with the 164T CNC main gear. Apparently the back lash (mesh) between the main gear and the pinion after the upgrade was too loose.
Yesterday on my second flight while doing Tick-Tocks the gear stripped. The headspeed dropped fast and I was able to auto the heli down, but at about 3 feet from the ground the blades didn't have enough headspeed and it dropped on it's skids. It bounced and landed on it's side. Hopefully, the damage was minimal. One link from the FBL head popped and the other one broke, blades, not even a scratch on them, one of the plastic Align servo wheels skipped some teeth, but the servo is just fine and the throttle linkage needed readjustment.
First crash with this heli in two years..., but I got lucky.
Here is a pic of the gear.
As you can see it stripped pretty clean.. This is the CNC Align 164T gear. http://www.align.com.tw/shop/product...oducts_id=4109
I installed the classic 164T, -1 main gear and the mesh with the pinion feels much better and positive.http://www.align.com.tw/shop/product...oducts_id=2610
I don't know how it will work with the Mod .01 gear setup, but I heard from Heli-Copteron that works fine.
Name:	Stripped CNC gear.jpg
Team GrandRC
Old 11-28-2011, 09:35 AM   #9
CFHeli1
I like the looks of it. Just ordered one from Helidirect.
CFHeli1 is offline        Reply With Quote
Old 11-29-2011, 01:52 PM   #10
ualdrivr
Yes it does look great. If it wasn't for the stripped gear I would give it a two .
Team GrandRC
Old 11-29-2011, 03:40 PM   #11
Chris Lalonde
So if mine is the older vir is it still ok to use? was there something wrong with it?
Old 11-29-2011, 04:50 PM   #12
ualdrivr
I don't think that there was anything wrong with it. It was suppose to be adjustable for gear mesh, but IMO and I think they realized that as well, it is a mute point. There is very little room for movement of the clutch stack since the start shaft runs through it and it goes all the way down to the clutch's one way bearing. The older version has the metal notch on it as well in order to snap into the frame's slot. The newer version doesn't and it's easier to remove from the heli, if needed. You just loosen six screws, undo the elevator servo linkage and the whole thing slides out of the frame.
Team GrandRC
Old 11-29-2011, 08:50 PM   #13
Chris Lalonde
Cool thanks for the info
Old 11-30-2011, 01:39 PM   #14
ntwaddell
I have one too, great upgrade! It was such a pain to get the clutch out before. I accidentally ordered two, so if anyone wants my 2nd make me an offer. It's brand new, never opened.
Align T-Rex 450 Pro FBL
Align T-Rex 700 Nitro FBL
ntwaddell is offline        Reply With Quote
Old 12-01-2011, 05:35 PM   #15
Chris Lalonde
Got my lynx clutch and clutch stack today. it was the new unit, they must of had the old pic on there site. All installed and ready for test flight this weekend.
Old 12-01-2011, 05:43 PM   #16
ualdrivr
Nice, I don't think the older version is available anywhere anymore.. Let us know how you like it. Which main do you have on the Heli Chris?
Team GrandRC
Old 12-01-2011, 07:28 PM   #17
Chris Lalonde
I have the stock main gear. Ya I was hoping for the new unit but they had the old pic so wasn't sure what I was going to get,
Old 12-01-2011, 08:59 PM   #18
ualdrivr
Looks great Chris, isn't it easy to get it in and out of the frame? I love it for that
Team GrandRC
Old 12-02-2011, 04:19 PM   #19
Chris Lalonde
Tried it out today. The lynx ctuch works awesome and the oneway worked even in the cold
Old 12-03-2011, 08:46 AM   #20
Felt
What did you use to adjust the gear mesh? Like in an electric I use a piece of paper folded over.
