| Painting and Airbrushing Tips / Techniques Painting and Airbrushing Tips / Techniques |
I was putting on my last coat of primer and then my canopy fell
. In the process of sanding it smooth again and basically starting over. Will post pics when done.
Blade 130X Xtreme-Production
Blade mCP X (Bl) Blade Nano CP X Prôtos 700 |
Be glad you werent clear coating it.
Yep, I just scraped it all off. It's just that it was the last coat I was putting on and it was perfect. Now it isn't quite perfect, but pretty close.
Did that on the 1st lid I did for my 1st T600... Dropped it right on its nose and shattered the tip of the canopy. Quick coat of epoxy inside and then some epoxy and microballoons to fill in the busted out gelcoat and you'd never know it'd been dropped.
-Kevin No helicopters were harmed in the creation of this post. AMA CD # 7309, Turbine Waiver# RW 890 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#6 |
When i blow it this early, i'm grabbing a rag and thinner and wiping it clean. It happens...... at least this way your right back in the game in minutes. Depending what kind of primer, keep it thin as possible unless it's a 2k type
US Drones Aerial Media Pros Ritewing |
#7 |
A few months ago, with the help of a dog, I managed to drop a lexan body I had just put the last coat of clear on straight into a hot oven. Watched it curl instantly.
7HV | sz 4926 | Hyperion Phase sensor | Helijive 120 | VBar Fullsize Blue | Torq HV's Trex 700e 3G | 700MX | Ice 120 HV | WR Hercules | I2 Tri-Blade Tail| RotorTech 105's | Voltz 3300 6s x2 | Lynx Spindle Bolts |
