Old 11-27-2011, 09:44 PM   #1
Elliott000
Default dx8 elevator always -1 in expo/DR screen
Ive been having an issue with me choppers both my trex's 450 FB and 550 FBL having slight backward drift. Found in my DR/expo screen on ele channel i have a consistent -1 on the output.... preoblem found but how do i fix this? im runnin airware. 1.04 or whatever the newest is!
thanks
Elliott000 is offline        Reply With Quote
Old 11-27-2011, 10:12 PM   #2
Slyster
thats normal. I think 3 of my channels say -1. But they ALWAYS say -1 which is the good part. But if you think that could be the issue (might be?) you can calibrate the sticks and that should fix it. I haven't done it, but I know its in the manual and in the menus.
"It's not just a hobby... it's a lifestyle" - Pete ϟ
Slyster is offline        Reply With Quote
Old 11-29-2011, 06:25 AM   #3
wanderer56
Use a blank channel without any sub-trims, trims, etc.linear pitch and throttle curves. Rx does not have to be on. Do the stick calibration, then switch back to the original model and see if that works.
Trex 500-3226-1600, 14T, Koby 90LV, HS-5245MG, DS655, AR7200BX, DFC
Trex 450 Sport-2221-8, 15T, CC Edge 50 Lite, HS-5065MG, HSG-5084MG, AR7200BX, DFC
DX8
wanderer56 is offline        Reply With Quote
Old 11-29-2011, 10:17 AM   #4
Elliott000
Did a stick cal and got it sorted
Sent from my GT-I9100M using Tapatalk
