| JLog - The JIVE logging stamp JLog - The JIVE logging stamp - Official English Support Forum |
Hello !
I have J-log 2 and I also wish to konect GPS senzor from SM modelbau via Jeti Duplex telemetry to have real time data. What cables I need to buy from SM too hook up all together and wich firmware I need to upload an dofcourse how too to hook together ? I plane to put this stuff on my TDR for drag trinig, it it useful for that purpose ? Anybodey have experiences with this combination ? Rregards
A je to ? |
Hi!
JLog can sniffer and log speed and altitude from a SM GPS-Logger by two means: a) Standalone (no telemetry): JLog is the busmaster on a Multiplex Sensor Bus (replacing a M-Link Rx). --> b) Both devices are Multisensors on a Multiplex Sensor Bus, means we use M-Link telemetry, a M-Link Rx is the busmaster as normal. --> No chance for JLog to sniffer data of another sensor on a JETI terminal bus. The only thing you can do: Use a JETI Expander, connect the GPS-Logger and JLog2 each to one of the 4 ports of the expander. The cable of the expander connects to the JETIduplex Rx. Each device logs on its own. You may monitor data by a JETIbox by switching between both multisensors. No other cable needed besides the telemetry cable from SM. --> Special firmware versions if needed (Multiplex Sensor Bus! Tom
Tom (http://JLog.hacknet.eu) Last edited by dl7uae; 11-28-2011 at 05:35 AM.. |
Hello !
Well I hooked with jeti expander, everything works, exsept acustical alarms. I get alarm on the display but no acustic at all. Any idea what is wrong ? Thanx
A je to ? |
Hi. Check this.
Tom Ummm... There was an update on an alarm issue, alarms through a JETI expander (months ago). Do you have the latest firmware on your JLog?
Tom (http://JLog.hacknet.eu) Last edited by dl7uae; 01-24-2012 at 02:53 AM.. |
Hello !
I havev fixed update it...it works now.... Thanx
A je to ? |
