Old 11-28-2011, 04:26 PM   #1
mark.w
Talking my trex 450 pro belt version (clone)
Just finished my second heli build a 450 pro with belt version tail, all has gone well other than the smallness of this heli can be a b!"$%^&d to wire. my tx has been placed at the front were the esc would normaly go,
This is the total cost of my build less the futaba 2.4ghz 6ex and R617FS, sorry have to say every thing came from the internet either ebay uk or ebay HK
trex kit 56.00
canopy 6.07
motor 7.00
40amp esc 7.90
lipo 2600 30c 13.37
Carbon Blades 3.12
Gyro 105 9.20
landing skid upgrade 3.19
digital tail servo 7.43
3x Cyclic servo 13.00
A total of 126.28, which i think is not paid for a full flying heli.
ID:	269731   Click image for larger version
ID:	269733   Click image for larger version
ID:	269734   Click image for larger version
ID:	269735   Click image for larger version
mark.w is offline        Reply With Quote
Old 11-29-2011, 12:39 PM   #2
Montfly
Looks good!
Tarot 45O PRO
Canadair CL-415
SkySurfer 1400
Montfly is offline        Reply With Quote
Old 11-29-2011, 01:55 PM   #3
mark.w
thanks montfly, i was beginining to think may it looks a pile of clone s!"t, hence no comments.,
mark
Old 12-03-2011, 02:13 PM   #4
Ger2010
trex kit 56.00
canopy 6.07
motor 7.00
40amp esc 7.90
lipo 2600 30c 13.37
Carbon Blades 3.12
Gyro 105 9.20
Hi. Very well done, I also have an HK clone 450 Pro belt version, with Aling servos and the 520 Futaba gyro, fasst receiver and 10C Futaba radio, I can tell you fly really good. Nothing to miss from an orginal.
Anyway Im looking for for the complete body, the same kit, no electronics, If you know where to buy, please let me know.
Thank you
Gerardo
Ger2010 is offline        Reply With Quote
Old 12-03-2011, 03:34 PM   #5
mark.w
The kit is still available on eBay.com. there is a clone pro kit with torque tube for 59 quid, or my kit is still available
Old 12-05-2011, 01:39 PM   #6
gdmaxwel1974
Default 450 Pro Manual
I just purchased the EXI clone of the 450 Pro with belt. Do anyone know what manual is the correct one to reference? I have the latest version I downloaded from heliproz.com but the ball links for the three servos and two ball links for the swashplate referenced in the manual are much shorter than the ones that came with my model. I just need to make sure I am setting up these links correctly.
gdmaxwel1974 is offline        Reply With Quote
Old 12-06-2011, 08:12 AM   #7
mark.w
I down loaded the both manuals for the pro and sport printed them off and took out what pages i needed to make up my heli, the pro main body, canopy servos, and the boom-tail from the sport.
To be truthful thou non of my swash links matched the given measurements on the pro or the sport, luckaly i had some help in here and used basic heli procedure for setting up the head that gave me + and - 13 pitch and everything level at 50% throttle
Hope this helps you
Old 12-20-2011, 08:52 AM   #8
hoverhead47
I assembled a Tarot 450 Pro and changed out the TT for a belt drive. The problem I had was that the tail drive gear was out of round and kept disengaging the tail drive. I replaced the gear on the free wheel clutch and the same thing happened. So I reconverted back to TT. Now after a slight tail strike that stripped a tooth of the bevel gears, I've gone back again to the belt drive and again have the disengagement problem. I originally thought the the issue was the tail mount and that it replaced but that wasn't the cure. Anyone have any ideas how to adjust the meshing of the tail drive gear?
hoverhead47 is offline        Reply With Quote
Old 12-21-2011, 04:02 AM   #9
mark.w
Any chance you could upload a photo to show us, meshing is fixed via he tail boom, the tail boom screws holes have to line up with the frame and there are 2 noggins either side of the heli just check this, if you want measure your main gear and let me know,
Just another thought have you checked your bearings in your tail boom holder
Old 12-25-2011, 10:22 PM   #10
satgod
nice build and your right
you probably wont see an difference at all in yours and an align counter part
to a beginner there would be no difference anyway as they have nothing to reference against
4 x Rush 750/stretched V-bar KDE 700XF-495 HV servos Greys reactor CC 160-HV
Trex 600EFL V2 V-Bar ds610 ds650 CC bec/pro Scorpion 130a HV KDE 600XF-530
450L KDE 1750 cc50 4xDS215MG k-bar
X-8 FPV Wing, TBS Discovery FPV, TBS Caipirinha FPV
satgod is offline        Reply With Quote
Old 12-26-2011, 12:01 PM   #11
srt4tom
I enlongated all the holes and the tab holes the same dia. as the holes and gave me the adjustment I needed. I found the high point of the gear and marked it, then lined it up with the drive gear with all the screws snug and then adjusted the mesh till It had near zero lash and then tightened everything up and it worked fine for a year now.
srt4tom is offline        Reply With Quote
