| mCP X Blade Micro CPx Helicopters Information and Help |
I just got this and noticed the upper balls seem a little smaller than stock. I placed the rotor links on the upper balls and they came right off once I turned on the heli.
I went and got new rotor links and when I installed them they seem to fit better, there was a slight click when I pressed them to the upper balls. But the links still seem like they can easily come apart. I have not tried flying with the new links yet, wanted to check with you guys if this was normal. Should I put a dab of ca glue on the upper balls? I emailed microheli support and all they said was try new link. Thanks for your help! |
I had no issues once I made the switch but I do have an odd link now and then that the hole was a tad bit large and would slide right over the swash ball both on the stock and MH swashplate...
#3 | |
Team Newb pilot MCPx brushless conversion (HP06V2 motor/HP03 tail),Trex 450 Pro V2 (KDE450XF motor,iKON),Trex 500 ESP (KDE500XF motor, iKON),DX7, AMA# 966513. PM me about mCPX & NanoCPX BL conversions. |
I have same issue as previous posts..an odd link every now and again. I blame blade/horizon not microheli. The micro heli swash was prob best upgrade besides brushless motor and solid carbon tail boom
Sent from my Atrix 4G using Tapatalk
Steve ALEES Rush 750 - Vbar Silverline -YGE160HV, Scorpion 4525-520 OUTRAGE Fusion 50 - Vbar Silverline, Jive 80HV, Quantum 4125-560 |
Thank you guys for the replies!
#6 |
Instead of plastic bags, use a piece of Saran wrap, or plastic wrap.
#7 |
...or teflon tape to be used on pipe threads. That thing is super thin and super slick. It's teflon afterall.
#8 |
Hope this isn't too off topic -
I just got my swash - the instructions with it say to loctite all the screws - Is this necessary, or is it just for replacements ? |
#9 |
I worn off those two balls completely on my first MH swash, and I thought I was being smart by using tiny bit of JB Weld and fine sand them to fit on those itty-bitty balls.
Eventually I got sick of reapplying JB Weld and ordered four more sets of ball links when I bought my second MH swash for my second mcpx. I have a bag of worn links and another bag of very worn links, and I have just tried using a small bit of plastic on the old MH balls. Works great! Great ideas guys! That's why I love this forum. Edit to add: to add a small scrap of plastic shopping bag material in the spare part bag when I go flying. |
#10 |
sorry to change the topic slightly, but on my MicroHeli swashplate, I noticed one of the balls is loose (not all the tightened down). How do i go about tightening these tiny balls?
I am worried to use a pliers (might distort the shape). On my 450, I can use a 1.5mm driver ... but on the tiny MH - I do not see how to grip the ball Also ... should I use some kind of loctite? |
#11 | |
Beam E4-(Scorpion HK-2221-6,11T pinion, Phoenix 60, HS65MG cyclics, GY520),120SR, Trex 250SE (stock) MH bottom plate,GY-520,Futaba R6106, MCPx,DX7se,Futaba 8FG Super, DJI Flamewheel F450 w/Naza/GPS, HPI Vorza on Futaba 4PL. |
#12 | |
![]() I measured the 1.5mm balls at 1.44mm and 1.40mm, the 1.40mm one was noticeably sloppy when I build a complete new head to use, not happy, you bet. ![]()
DJI Naza 330, 450 & 550 hexa, TBS Discovery (Naza-M/5.8Ghz vid link/ET telemetry), KK2 micro hexa and micro quad, Nano Ladybird/Spektrum Hybrid, Nano MQX hybrid. 300X, Trex 450 Pro DFC, mCP X's, mSR X, nano CP X DX18, 14SG To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#13 |
I definitively had a bad MH swashplate, very small balls, should not happen with premium equipment.
#14 |
it was the only thing i didn't like about the swashplate, them top links pop on and sit very loose.
#15 | |
After I posted this I got a new pack of rotor links and test fitted each one, some were real loose and some were perfect. Microheli sent me replacement balls but I never installed them. Good luck, Steven |
#16 |
Does anyone else beside Blade make replacement links?
Blade mCPx and Spektrum DX7 |
#17 |
Yes.
http://www.ebay.com/itm/AEO-RC-Blade...item43ac15748b I've been testing these for a while. I use one blade and one aeo on my c05m heli. I've broken 4 of these to 0 of the blade parts. And that's with a microheli head with link retainers. Problem could be that these are a tad thicker and rub against the retainers. These bend easier, and snap easier, and just generally don't fit as well as stock. Won't be buying them again. |
#18 |
i use a dab of hot glue on the trouble links, comes off real easy and lock the links on.
stated doing this with the stock setup i do agree that they need a better quality control for these parts for the price were paying for them |
