Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 450
Blade 450 Blade 450 Helicopters Information and Help
Old 11-29-2011, 09:17 AM   #1
Like2fly
Default Flybar seesaw replacement?
I managed to damage some of my flybar cage and the seesaw while trying to get a bent flybar out.
Now while I am waiting for replacement parts, I get in doubt on how to reinstall the seesaw:
My head has still what appear to be a screw and a bearing in it on each side. Are these screws supposed to go into the seesaw? I am asking because right now, it looks like the screws only just go through the bearings and holds a small washer on the inside part.
So I am wondering if the seesaw is just a tight fit between these, or if the screws are supposed to go through the bearings and into the seesaw?
Thanks for helping me out ;-)
Like2fly is offline        Reply With Quote
Old 11-29-2011, 06:18 PM   #2
spykez
Hehehe, you too eh? Welcome to the club.
http://www.helifreak.com/showthread.php?t=359055&page=2
Still in exile. FML.
spykez is online now        Reply With Quote
Old 11-29-2011, 06:37 PM   #3
PauloG
Haha sorry... I had to laugh... Otherwise I'd be crying... That is the most annoying part to replace on the B450.
One advice... Take a deep breath and count to 10
Goblin 700, Goblin 380, Gaui NX7, T-Rex 700N, T-Rex 450
iKon, because I am connected to my heli. Are you connected to yours?
RCHN #15
PauloG is offline        Reply With Quote
Old 11-29-2011, 09:46 PM   #4
Merced69
Merced69 is offline        Reply With Quote
Old 11-29-2011, 09:54 PM   #5
Being
You'll figure it out but to help you along, the seesaw goes into the bearings and the screws secure it there.
Being is offline        Reply With Quote
Old 11-30-2011, 02:35 AM   #6
Like2fly
I guess you mean the seesaw fits between the bearings, and the screws secure it there?
If I am correct, my point is, that the screws still in the head seems to short to go/reach into the seesaw, unless what I see is only a part of the the two screws remaining in the head?....
I have tried to attach a photo, to illustrate the screws in question.
Old 11-30-2011, 02:55 AM   #7
spykez
Yep, just remember to get it in the right orientation. Or you'll be kicking yourself later. Exploded parts diagram and Thalios's sticky plus that thread I linked will help.
Old 11-30-2011, 03:17 AM   #8
Like2fly
Thanks a lot, I'll read the thread carefully again ;-)
Old 11-30-2011, 06:17 AM   #9
Like2fly
OK, pls correct me if this sum up is wrong:
  • I have to take out at least one of the bearings in the head in order to get the seesaw back in place correctly
  • The orientation of the seesaw is important and should be with the ball on the left each side, when the seesaw is viewed from paddles position
I understand it is hard to get the bearings in/out, and had hoped to replace the seesaw without removal/reinstalling of the bearing
Thanks for chiming in ;-)
Old 11-30-2011, 07:50 PM   #10
pilotlevi
I drilled my out and just replaced the bearing... To me paying a little money is worth the headach...
I then proceed to install the seesaw backwards and had to drill it again.... lol
pilotlevi is offline        Reply With Quote
Old 11-30-2011, 08:35 PM   #11
Being
No...the nubs on the seesaw (or the brass insert if you use the aluminum seesaw) go into the bearings.
Old 11-30-2011, 08:41 PM   #12
Being
It's impossible to install the seesaw with both bearings in place. I think you should take the screws out because they are screwed into part of the seesaw that broke off...the nubs I mentioned above. The nubs go into the bearings not between them.
Old 12-01-2011, 03:01 AM   #13
Like2fly
Thanks a lot for correcting me!
Everything is clear now, where I have gotten one of the bearings out: A small piece of broken seesaw covered the end of both screws. Now I understand that a small cylinder shaped part of he seesaw ("nub) goes into the bearing, and that the screws goes through the bearing and into the cylinder part of the seesaw.
So obvious now, when it is apart, but hard to figure out when something is missing and you don't know exactly what.
Thanks!
Old 12-03-2011, 02:14 AM   #14
Being
Thanks!
Glad I could help. I owe this community alot for all the help I've received since I joined.
Old 12-29-2011, 03:14 PM   #15
Musiqfan
Default Replacing Flybar Seesaw Holder
I was finally able to replace the Seesaw holder by removing the bearings for both sides. Take special care when removing the bearings.
Once the bearings have been removed, insert the Seesaw holder into place and install one of the bearings. Make sure that the hole of the bearing matches the hold for the screw into the Seesaw.
Place the head on a flat surface and rotate for the bearing installation. I used a socket from my socket set to push down on the bearing using equal pressure. You may also want to insert the screw about 1/3 of the way to ensure that everything is properly aligned.
With the bearing inserted about 1/3 of the way, flip the head over and insert the other bearing. Also make sure that the hole for the Seesaw and the bearing are aligned.
Press down carefully with equal pressure and the bearing should be installed.
Musiqfan is offline        Reply With Quote
Old 12-29-2011, 10:46 PM   #16
Ron~FordTech
Correct.
Sorry - it cannot be done with both bearings in place. And to further clarify...
The seesaw has a pair of "horns" or "pivot shafts" directly opposite each other. Each of those "horns" inserts into the I.D. of the seesaw bearings and ends up sitting essentially flush with the outside of the bearing(s). So the securing screws engage with the seesaw "horns" immediately as soon as you begin threading them into place. Therefore they only need to be 2 or 3 mm in length because they are not doing any work; merely locking the bearings into the head (which is somewhat silly since they require such force to remove even when the seesaw is not present!)
Ron~FordTech is offline        Reply With Quote
Old 12-30-2011, 03:55 PM   #17
ianl9
deleted
ianl9 is offline        Reply With Quote
Old 12-30-2011, 04:07 PM   #18
Being
Originally Posted by ianl9 View Post
deleted
Aluminum seesaw (BLH1623A) comes with the brass insert, screws, and balls.
Old 01-02-2012, 10:25 AM   #19
ianl9
Ya I found them later, that's why I deleted my post. Thx
Old 01-08-2012, 02:04 PM   #20
fanch72
Hi
I just had a bad crash today with the same result that you describe... Could you tell me how you succeeded in removing the bearings? they seem to be so tightly fitted!
Thanks for some help!
Francois
fanch72 is offline        Reply With Quote
