Go Back   HeliFreak > R/C Helicopter Support > Henseleit
Henseleit Henseleit Helicopters
Old 11-29-2011, 04:49 PM   #1
Nutbag
Default Canopy Clips
Hey all,
Don't know if this had been posted before but are the little slots in the undercarriage legs put there by Jan to hold the canopy clips when not in use?
The clips just drop in and fit perfectly so don't fall out easily, discovered this when setting up on grass and looking for somewhere to put the clips so I wouldn't lose them.
Chris.
Henseleit TDR Xera Vbar gov, MA whiplash YS120 VBar gov, Rex700N VBar gov, Stretch 450 Pro 6s Vbar , FPV Quad, Planks a plenty, Turbine Eurosport.
Nutbag is offline        Reply With Quote
Old 11-29-2011, 07:02 PM   #2
heli21
Thanks for the tip! I will typical just clip mine on my blades but now I have a real place to put them!
Rob
heli21 is offline        Reply With Quote
Old 11-29-2011, 07:30 PM   #3
cbdane
Ha, ha... Last Friday I had to return to the flying field near midnight with a flashlight to retrieve my clips from the table where I left them.
Have laser, will travel.
cbdane is offline        Reply With Quote
Old 11-29-2011, 07:46 PM   #4
donskills
Originally Posted by Nutbag View Post
Hey all,
Chris.
If that is the case, Jan just got another stripe on his shoulder!!
Henseleit TDR 2011, Spirit, BLS451/251,Pyro30-12, Kontronik Kosmik 200+Jlog2.6GW, Radix 710FBL, Radix 110 tails.
AccuRC, realflight 7, Jeti DS-16.
donskills is offline        Reply With Quote
Old 11-29-2011, 07:51 PM   #5
helicraze
Can you show me pic? Is Jan including clips now?
helicraze is offline        Reply With Quote
Old 11-29-2011, 09:36 PM   #6
Nutbag
Here ya go Michael, lucky I had the TDR with me at work hoping for a fly this arvo...
Iprobably should have referred to them as the canopy "R-Pins".
This pic just made me realise my how rusty my 12.9 Grade bolts are
Old 11-30-2011, 01:39 AM   #7
astrocyte
The struts on my 3DMP have that slot there which is intended for a zap strap to keep the strut from falling out if the screws loosen because the holes in the struts are slotted all the way to the top.I thought my TDR just used the same struts but no slotted mounting holes just holes.There's actually a few little parts carried over to the TDR from the MP.Geoff
astrocyte is offline        Reply With Quote
Old 11-30-2011, 06:23 AM   #8
shaman3
Great idea, Chris!!
shaman3 is offline        Reply With Quote
Old 11-30-2011, 07:42 AM   #9
HeliBenj
Cool, best tip in a long time, I never know were to put my clips when not on the posts
Ben
Goblin 500 IKON w/ gov, Quantum 4115-1200, Hitec 5245, BLS251
DX8, RF6
HeliBenj is offline        Reply With Quote
Old 12-01-2011, 06:07 AM   #10
Heli G
Hey all,
Chris.
I have to put the clips where I won't miss putting them back...maybe I'm getting old...
Heli G is offline        Reply With Quote
Old 12-01-2011, 09:15 PM   #11
esmoglo
Anyone know what clips work other than the OEM ones? I know there must be ones for cars that would fit but the bend is needed for a good fit......
Angelo
esmoglo is offline        Reply With Quote
Old 12-01-2011, 09:18 PM   #12
helicraze
I use kasama ones and shorten them
Old 12-02-2011, 01:48 AM   #13
HeliBenj
Just curious, why use other than Oem? They seem to be working fine for me
Ben
DX8, RF6
Old 12-02-2011, 01:59 AM   #14
helicraze
I never got OEM clips, maybe he only started sending them in 2011???
I bought TDR in 2009 and 2010
Old 12-02-2011, 02:26 AM   #15
shaman3
When I order parts from Jan, I usually type into the shop's comment field that I need some canopy clips, too.
He has never charged me for them, so can afford to lose one from time to time in the canopy-clip-sucking-and-hiding-them-forever lawn But Probably won't happen ever again thanks to Nutbag's idea
Daniel
Old 12-02-2011, 07:37 AM   #16
Heli G
Kasama ones work, but I like the bend that the ones from Jan has which helps with clipping/unclipping.
Yep, also started seeing the clips in my 2011 kit from Jan.
Old 12-02-2011, 07:52 AM   #17
Costas
These type of clips [Body Clips] are common place in RC car circles. Any good RC car shop will have these.
Costas is offline        Reply With Quote
Old 12-03-2011, 11:57 AM   #18
heli-lover
Coming from the nitro off-road world let me share a little tidbit from my racing days. You can get those clips at any R/C shop that carries Traxxas or any other brand of electric/nitro cars/trucks/buggies/truggies. It's the same clip that holds the lid on them too. Take a small pull-strap and put it through the clip hole. Tighten the strap down on the clip all the way. Cut off the excess length leaving about an inch of strap. NOW, you can see the clips AND you can grab that little strap and pull the clip out easily. Stick it in the hole the OP told us about when we're not using it and we have it all. Can't exactly miss seeing a colored strap on the landing gear now can we? And now, the dancing bananas...
heli-lover is offline        Reply With Quote
Old 12-03-2011, 06:35 PM   #19
neohp
yes but with the drag you will loose speed
neohp is offline        Reply With Quote
Old 12-03-2011, 06:45 PM   #20
heli-lover
