Go Back   HeliFreak > R/C Electronics Support > HobbyWing ESC's
HobbyWing ESC's HobbyWing ESC Support
Old 12-01-2011, 07:18 AM   #1
lgalarza
Default Idle 1 and 2 not work
Hi, I put im trex 550 HW 100A , when I change from normal to ST1 or ST2 not change
the RPM. I verify evrithing in the radio and all look fine. I use DX7.
I use in normal 75 % flat
ST 1 90% flat
ST 2 95% flat
Pls if you have idea wwhat is the problem let me know.
Thanks,Luis
lgalarza is offline        Reply With Quote
Old 12-01-2011, 07:27 AM   #2
superrmario
Make sure your end points are set correct in the ESC. You have to program them before you set your idle one and two.
In normal mode set your tx to 100 in throttle curve on the top point, and 0 on the bottom point. Then go to you ESC program and set it in there.
At this point the ESC will see the actual top and bottom of the left stick. Then adjust your Norm, idle 1 and 2 according to your desired Head Speed
I had the sane issue, common overlook.
Sent from my Droid Charge using Tapatalk.
superrmario is offline        Reply With Quote
Old 12-01-2011, 07:31 AM   #3
lgalarza
My endpoints in the radio are 100%
Old 12-01-2011, 10:50 AM   #4
superrmario
Yes, but did you program your ESC to see full up as 100% and full down as 0%?
It may only be programmed so when full up stick is applied its only give 80% of power.
Old 12-01-2011, 10:56 AM   #5
superrmario
See this thread i started a few months back..
http://www.helifreak.com/showthread.php?t=344199
Old 12-01-2011, 04:31 PM   #6
lgalarza
How I reprogram the esc?
Old 12-02-2011, 04:20 AM   #7
superrmario
Follow the directions. If you don't have them, you can download them from their site. You can buy the program card, or do it with your sticks.
Its hard to explain how to program.
Old 12-03-2011, 01:25 AM   #8
kachur779
i think this is where i screwed up so what u are saying is set esc to default change throttle curve to liner line 0 25 50 75 100 in normal idle 1 idle 2 program your esc and governer mode after thats done change idle 1 or 2 to flat 80 or 100
kachur779 is offline        Reply With Quote
Old 12-03-2011, 09:00 AM   #9
superrmario
You only need to change normal mode it the transmitter, but yes, you are on the right track. As for Governor, i dont know since i do not run one.
One thing that threw me was you need to have throttle hold "armed" so the TX transmits the signal.
Old 12-03-2011, 11:41 PM   #10
kachur779
k thanks i dont no what u mean by throthle hold are u saying hold has to be on while doing this cause it says nothing about this in the instuctions
BLACKOUT MINI,ZMR 250,TBS Discovery ,Zephyr 2
TARANIS X9D + ,ez-uhf jr mod
GauiX5 Gauix3
Old 12-04-2011, 08:56 AM   #11
superrmario
Meaning when you program the ESC, hold needs to be on so it will see 0% and 100% when you move the stick.
When you program the ESC make sure you have 2 motor wires unplugged, or take tail and rotor blades off. Even though programming mode does not arm the motor, it is better safe than sorry.
Old 12-04-2011, 06:12 PM   #12
Inverse
No, hold needs to be off.
Compass 3D+ - OS55 Hyper/Hatori/Vbar
Atom 500
Tarot 450 Pro - AR7200BX
Spektrum DX8
Inverse is offline        Reply With Quote
Old 12-04-2011, 07:18 PM   #13
superrmario
Hold needs to be "Armed", meaning hot, and not safe to move throttle stick unless you are away.
I always get confused with Hold on, hold off. To me, "on" means head is spinning.
Old 12-05-2011, 03:23 AM   #14
Helis4me
I had the same problem before I had to redo my throttle end points in ESC and then it was good.
Just make sure before you redo your end points in ESC have a linear throttle and pitch curves and in travel adjust have +/-100
I had my throttle hold at 0 then adjusted where throttle hold works.
Cheers
Trex 600E Pro FBL with V-bar,600MX-510KV,HW 70A HV ESC,
CC BEC Pro,Align DS610,Futaba BLS251,
JR11X with Hyperion LifePO4,
Icharger 306B with Meanwell 1000W 24v power supply.
Helis4me is offline        Reply With Quote
