| BeastX FBL System BeastX FBL Flybarless System Software and Hardware Support |
i set up my beast x, as per the manual, on the swash leveling step, everything is 90 with 0 pitch, but after the beast x initializes my midstick is -6 degrees does anyone else have that problem?
at midstick in the servo menu, my pitch channel is at 0 but i have -5 degrees, i have no subtrim, my travel is 100/100 my pitch trim is INH and my hover trim is INH.... im baffled... also when i get to the cyclic geometry point, my blades dont start at 0 degrees, is that normal?
DX8i, 8FGS, Phoenix, icharger Trex 450 pro V2, µBeast, HS-5065's, Ice Lite 50, GensAce, Exi FG 325's 450MX Prôtos 500 6s 16T µBeast, 9650s H6080, Ice Lite 75, WR 5A BEC, SAB |
No issue here.
Are you leveling at menu G while subtrim is active? |
Do u have a futaba TX or futaba servos?
I have futaba 3156 as my cyclics and had a similar issue (using a dx8) and I had to redo step k like 4 times before it would be 0 at mid stick when all the other setups were perfect. It was weird but finally worked. Good luck! |
Do you have a linear pitch curve when you set it up? Might want to check that...
AMA #976001 HELIS: TREX 500 (6s), Trex 600 ESP (12S) & Trex 550 (12S): ALL FBL To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. PLANKS: Hangar 9 Pulse 60, Alpha 40 & Great Planes Revolver |
Im using a linear pitch curve and 5065mgs
Sent from my DROIDX using Tapatalk
#6 |
What about menu G? You should at least give one rudder input to get all three servos at neutral position before leveling swash and setting 0 pitch.
#7 |
+1.. menu G looks like it hasn't been done correctly.
First remove cyclic servo horns. Then power up and get to Menu G.... at this point put servo horns on as close to 90 as possible. Then using the procedure in the manual for Menu G make the individual horns perfectly 90. Then exit the setup menu and see if all your horns go to perfect 90. With the collective stick at midstick(motor unplugged). After the servo horns are set for 90 then make sure your links are the correct length. Typically I measure according to manual and it should be correct. This should also help with your issue with the cyclic geometry step being off at the start.
Trex 450 Pro 3xDS410M + MKS8910A+, Align FBL head w/Microbeast, CC 45 Gov@ 3400rpm(max timing, outrunner mode), Scorpion 2221-8 on 14t, Edge FBL main and tail, CF boom, CC BEC @ 6V |
#8 |
Have you disabled hover pitch and hover throttle in the radio?
Roll the LD and RD knobs and see if your pitch/throttle curves change, these mixes need to be inhibited.
Edge Rotorblades Thor/Voltz Batteries 450 Pro V-Bar 130X |
#9 | |
Is there a chance that when you set your collective limits I may have not had the stick fully down or up, and its messing with things? Should I have 0 pitch at midstick on that step too? Sent from my DROIDX using Tapatalk
#10 |
Right now when you power up with stick at zero do the servos go to 90? Motor unplugged.
#11 |
Reset MB, at set up menu, hold the button for 10sec and the swash will jerk 3 times.
You have to redo everything, including receiver set up after you reset MB. |
#12 |
To be clear. You must exit Step G with a colored light on. When you finish centering the last servo don't push rudder again. Just exit to "H".
G.
T-450 Sport FBL, T-550 V1 FBL, T-600E Pro. Red Goblin 700. Tarot Pro 450 in a scale Hughes. Bunch of little Blades, and Planks. DX8, Full scale Jet Plank Driver. |
#13 | ||
does that set the 0 pitch on the tx? or does the step when you set max -/+ collective set midstick by taking the middle of the servo travel?
#14 |
Midstick is set at menu G, that's why 0 pitch must be set at menu G. Menu K will let you set min and max pitch while keeping 0 pitch at mid stick.
Another way to check 0 pitch is entering param menu A (trim, remember not to move the ail/ele or you will trim and remember leaving the menu before spooling up). |
#15 | |
When you then create the modified positions for each of the servos it now has a new centre value stored. For example these might be 1507, 1529, 1519. As soon as you leave G these values should be stored to the MB. Once you go to step J, the MB will output these stored values to the servos, so if you do not get 0 degrees at this point, having already had it at G, then either you didn't do it right, or the MB has somehow forgotten. When I exit G, if I do it with a light on, the servos do not move, and they remain where they are, so it must still be zero at H and J. If you do this with your stick at zero, when you get to step I, your swash should shoot to the bottom, because step I responds to your stick inputs so you can set the motion correctly. When you go from I to J it should shoot back up again to the stored new centres created at G. If I leave H with my stick accurately at mid stick, there is no swash movement as I go into I either, so it stays put all the way through. Do this. Go into set-up G, push rudder to the left, once, briefly check for 0, you should have it, you've already done it. Push Tx collective stick to mid stick, to ensure swash should not move, then exit G to go into H. Nothing should move. Now go from H to I, nothing should move (Might be a tiny twitch here, as it is difficult to put your Tx stick at exactly mid stick, but it should stay level. If it is exactly at mid stick, and it moves a lot, there is an issue here). Now exit I and go into J, nothing should move (except again, maybe a tiny twitch). If nothing does move (significantly), then you must still have zero on your blades at step J. I know this is a bit of overkill, but I thought it couldn't hurt so I have just made a little poor quality video to show that nothing happens between G and J when you are at mid stick on the Tx, unless there is something wrong. Will have to wait for it to cook on youtube I guess. Let us know what happens with yours. Cheers Sutty
Regards, Sutty BeltEXI, mCX, mSR, 4G3, FBL Trex250SE µB, FBL Trex450Pro µB, FBL Trex550e VX1, FBL Trex600ESP µB, Parkzone P51D |
#16 | ||
ill try that Quote:
and that video might have been overkill, but it just kept me from asking another question lol... and i thought setting up a FBL machine would be easy lmao... it is my first kit though...
DX8i, 8FGS, Phoenix, icharger Trex 450 pro V2, µBeast, HS-5065's, Ice Lite 50, GensAce, Exi FG 325's 450MX Prôtos 500 6s 16T µBeast, 9650s H6080, Ice Lite 75, WR 5A BEC, SAB Last edited by nick779; 12-05-2011 at 10:18 PM.. |
#17 |
Just a suggestion but first a few questions, did you set up this model in the radio from a blank model?
Or was it a previous model or one that you copied over that you just felt like you had changed over everything right? As far as my suggestion is, can you put this Tx and this model on any simulators you might have? Being as it is setup for a no mixing now you should be able to do this and then maybe you could double check that your Tx is sending all the right neutral points or if it might be sending something you just haven't found yet. Would be a nice way to confirm 100% you are not getting something wrong from the Tx. |
#18 |
Wouldn't completely rule out Tx issues, but my point about G and J still stands. Servo positions output at G are created by the MB, and modfied by you at step G and are then stored. These modified positions are again output by the MB at step J, before you start adjusting in J, so if you are no longer getting 0 degrees when you enter J, when you had it in the modified positions at G, then, in my opinion, there is something wrong prior to considering issues with your Tx. I would examine this area first, and ensure that you get the same values/positions at both modified G and at unmodified J.
If of course you do get the same at G and J, in the same way that I did in the video, then of course you must look elsewhere. Good luck with it. Cheers Sutty
#19 |
well i just finished my beast setup, ended up moving back to the 2nd hole on my hs5065s
i have +/- 14 collective and 14 cyclic, but my midstick is a hair over +1 degree... which bothers me, but i really dont care right now, its one degree and i just want to maiden the heli
