| X5 Discussion and support of the Gaui X5 |
Well, my tail wag is back. I've replaced my tail thrust bearings and I have no binding or vibes. The only thing that seems to work is turning the tail frequency down to 165Mhx on the BeastX, but the tail doesn't hold as well through pitch pumps.
I thought I'd try another tail servo. Worst case I sell it to one of you guys for a slight loss if it doesn't fix it. I'm looking at the Torq 9188... I'm on the stock ESC/BEC and I really don't want to buy anything else, specs show it can be run at the standard 5V, although the stock BEC does have a 6V mode too. Is that pretty much the best bang for the buck right now?
DX8, mcpX, Align T-Rex 450 SE v2 FBL(BeastX, Tarot Pro V2 Head), Gaui X5 FES Sk540 Thanks and Gig 'Em To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
there are alot of good choices for the tail bls251, jr 8900g, outrage 9188 and some mks servos i cant remember the number off hand. they are all around the same price but your right ive never heard a complaint about the torq 9188 thats what im going with
the 9188 @ 8.4 volts 2s lipo voltage is what is use.
best servo I ever had, hands down. I never really had a problem as long as I use good blades
Dx8 mCPX bl v1 hp05s130X GauiX2FESds11,ds95i beastx Gaui X5FES,AR7200BX,Xera4020Torq9088,9188 |
8900g is rock solid
________________ Gaui - MSH - Scorpion - JR - Byron - OS - MKS - Savox - Edge - Spin - Rails - Lynx - Gensace - Skookum - KBDD www.irchc.com |
Sorry if I'm bit of hijacking, but I can see both JR and Graupner 8900g servos. Are they the same/what's the difference?
http://www.graupner.de/en/products/5182/product.aspx http://www.servodatabase.com/servo/graupner/ds-8900g http://www.jrradios.com/Products/Def...odID=JRPS8900G http://www.servodatabase.com/servo/jr/ds8900g Graupner one seems to be cheaper for some reason - and can be run on 6.0v? |
#6 |
from what I understand they are the same but someone else hopefully can verify this.... I run a JR8900g
#7 |
I wouldn't recommend that servo for one reason. Coreless motors do not last as long as brushless..period.
If your on a low voltage application get a BLS 254 or 251 ( I have the 254, but the 251 is faster due to higher resolution) OR get the 9188 if your running high voltage. |
#8 |
I haven't had a lot of flight time since installing it, but the Futaba BLS 256HV has worked great so far too even on just 6V.
#9 | |
Im now after funds to replace my Inolab's with Outrage 9088 servos.. Hopefully the Outrage cyclics are just as good as the tail servos. MKS BLS980 (6v) or the high voltage version MKS HBL980 are 2 other excellent choice for tail servos. |
#10 | |
#11 |
If you arent locked to Futaba try new Savox BLS HV line.
Very impressive specs Cyclic http://www.savoxusa.com/Savox_SB2271...avsb2271sg.htm Tail http://www.savoxusa.com/Savox_SB2272...avsb2272mg.htm
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. - Croatian RC forum |
#12 | |
Team Synergy/Team Scorpion |
#13 |
sorry, I was referring to the JR DS8900G. It has a coreless motor. Whilst coreless motors are lighter than brushless, and can often be faster as a lower cost, they do use brushes. Brushes wear out. Brushless motors last forever (almost).
