Go Back   HeliFreak > R/C Helicopter Support > Compass Model Helicopters > Atom 500
Atom 500 Compass Atom 500 Model Helicopter Discussion
Old 12-09-2011, 04:42 PM   #1
sly the dogman
Default "J" déjà vu
Well point "J " is not a success friends, I got red not bleu. I get bleu at 6.9 degres
but I don't want 6.9. Included are a couple of pics of the servo horns and links.
Any advice...
We do accept FB parts for Compass 5.5
sly the dogman is offline        Reply With Quote
Old 12-09-2011, 04:44 PM   #2
sly the dogman
Sorry,
ID:	272345   Click image for larger version
Old 12-09-2011, 04:45 PM   #3
sly the dogman
Dam !
Old 12-09-2011, 04:48 PM   #4
Ah Clem
Sly,
I moved the ball in on the servo arm one hole to get the V-Bar set correctly.
I should think that would work on your machine, sir.
Your pushrod will no longer be at 90 degrees to the servo arm though.
Old 12-09-2011, 04:51 PM   #5
skinart76
I don't run a BeastX, but I do believe you need to move the balls in quite a bit on the servo horn.
skinart76 is offline        Reply With Quote
Old 12-09-2011, 04:51 PM   #6
skinart76
Oops, Ah Clem beat me to it.
Old 12-09-2011, 06:55 PM   #7
GimpyGolden
Or space the outer balls on the swash.
If you move the ball in one hole and find you get uneven collective range you can correct mechanically by rotating your horns 1 spline in the appropriate direction.
Or cheat and tune it out in radio setup.
GimpyGolden is offline        Reply With Quote
Old 12-09-2011, 07:28 PM   #8
TallPaul
The one hole in worked for me (on a Skookum, but same idea).
Compass Chronos; Compass 6hvU; Compass Atom 500; FLIP-FPV ; most with iKON; Spektrum DX8
TallPaul is offline        Reply With Quote
Old 12-09-2011, 08:49 PM   #9
sly the dogman
Its been a very long day, it'll give me something to fiddle with tomorow.
Thank you kindly folks.
Old 12-10-2011, 09:43 AM   #10
g2driver
About 15.5 mm on the servo horn and I did not place the servo horn level in reference to the main shaft... but perpendicular to the pushrod...
Raj Patel
COP Global Aviation
Senior Intl Captain
Humble, TX
g2driver is offline        Reply With Quote
Old 12-10-2011, 10:43 AM   #11
Jason O'Connell
Formerly BarnStormer
I saw Sebastian Zajonez fy his 5.5 at IRCHA last year. When I saw that his servo ball was not at 15.5mm I asked how he could get a blue light at those settings. He said "The blue light is not that important. Red will be fine just make sure to set it at exactly 6 degrees" Then he flew the following flight with it.
Team Compass USA
Scorpion Power Systems
Jason O'Connell is offline        Reply With Quote
Old 12-10-2011, 12:12 PM   #12
sly the dogman
There you go !
Old 12-10-2011, 12:50 PM   #13
chopstick
We drill holes at about 15 mm, and we get blue at 6,1 degrees.
The links aren't perpendicular anymore, but this seems to be no problem. The heli's fly very good.
LOGO 500 : Spartan Vortex Nano; Scorpion 4020 1100kV
Quad 250 : Openpilot CC3D
chopstick is offline        Reply With Quote
Old 12-10-2011, 01:03 PM   #14
Jason O'Connell
I did the same when I converted my old 500 to fbl. Worked great.
Team Compass USA
Old 12-10-2011, 01:51 PM   #15
sly the dogman
Apparently its the thing to do, pushed the ball back 1 hole and bleu appeared, magic !
Of course the swash looks like its on crutches, , but if it flies, that's most important.
Old 12-10-2011, 03:44 PM   #16
fulcrum2
You could put the servo arm in a different position on the spline to get 90 degress between rod and arm. Will not be aligned with the servo case any more but the geometry would be the same for pos and neg pitch...
fulcrum2 is offline        Reply With Quote
Old 12-10-2011, 05:12 PM   #17
sly the dogman
Thanks, but I think I'll leave them as they are now,
efficiency is better than prettyness, lol
And tonite boys and girls, we'll look at point " H " and behond.
Old 12-10-2011, 05:14 PM   #18
GimpyGolden
Actually Sly the other way would be correct and not as pretty.
Is you Coll range even top & bottom?
Old 12-10-2011, 05:49 PM   #19
sly the dogman
Sorry but what is "coll range", remember I'm a french speaking dude.
Old 12-10-2011, 05:58 PM   #20
GimpyGolden
Collective range, +13 High stick and -13 Low
