Go Back   HeliFreak > R/C Electronics Support > Scorpion ESC and Motor Support
Scorpion ESC and Motor Support Scorpion Power Systems ESC and Motor Factory Support Forum
Old 12-10-2011, 07:36 AM   #1
Dflyer
Question Scorpion 4035/500 in TDR ?? Is it ok or not ?
Hi guys,
i have bought a second hand TDR but it came with no electronics. The pinions supplied are only a 15t and a 16t.
Is it ok if i put in a Scorp 4035/500 in combination with the 15t pinion ?? I also have a Scorp 4035/560 laying around, but i think that will be too much in combination with a 15t.
What do you guys think ?
thx dirk
The heli virus has infected me and i hope that there is NO CURE !! Compass Support Team
__________________________________________________ _____
ATOM 500 FBL (BeastX) / ATOM 6 HV FBL (BeastX) / 7HV FBL (BeastX) / Henseleit TD R
Dflyer is offline        Reply With Quote
Old 12-10-2011, 08:42 AM   #2
7.62x51
What regulator will you use with it?
With a Jive it will work fine.
Stock 4035 may be not the strongest motor;
i've a rewound 4035 and now it works cooler and push hard.
Henseleit TDR; Alees Rush 750; Synergy E7; Miniature Aircraft Whiplash; Compass 7HV; Hirobo EMBLA.
Fabio
7.62x51 is online now        Reply With Quote
Old 12-10-2011, 10:48 AM   #3
Dflyer
Hi,
i will be running a Jive 80HV with heatsink.
Grtz,
Dirk
Old 12-10-2011, 06:31 PM   #4
7.62x51
Should be enough.
Maybe borderline for hard 3D.
My Jlog shows 170A making tic-tocs.
I use a PowerJive 120 and a rewound Pyro.
Fabio
Old 12-10-2011, 09:53 PM   #5
marcosp
It's almost the same as the Pyro so should work fine as a standard setup.
Marcos
Banshee #27, 2x TDR, Diabolo, JR Sylphide E12, Voodoo 600, Voodoo 400, Avant Aurora 90N, Rave 450, Gaui X2
marcosp is offline        Reply With Quote
Old 12-11-2011, 02:06 AM   #6
helicraze
Yep, use the 15T, or use the 560KV and 14T, i like higher KV motor if it allows
helicraze is offline        Reply With Quote
Old 12-11-2011, 02:16 AM   #7
Dflyer
Hi Helicraze,
what's the advantage of the higher KV motor on the TDR ?
Grtz,
Dirk
Old 12-11-2011, 03:22 AM   #8
Danny_Swe
I have a similar question, would the Hyperion HS4035-560 be a good choice? With a 14T? It's on 4kW continously so would be a little more powerful than stock I hope.
TDR, 550E, 450Q | VBar, YGE, DX8 | Olympus OM-D
http://dannesholk.se/rc.shtml
Danny_Swe is offline        Reply With Quote
Old 12-11-2011, 04:52 AM   #9
helicraze
Yeh the hyperion is good made by scorpion.
Higher kv seems to bog less due to inertia of the can. Feels more powerfull.
Old 12-11-2011, 06:58 PM   #10
kmiglis
upon 14t i jloged 6.5kw sustained (130a) during speedrun with 15 deg pitch (2150rpm)
this motor can give much more than the specs and has a good compromise between flighttime and performance on a hv80jive with heatsink, dedicated fun and Mick naca duct.
idle1 1350rpm soft3d 10min
idle2 1650rpm 6min
idle3 2150 4 speedruns no time here.
4000mah nano 35c.
i hope that good information were provided.
temperatures are all average nothing to worry!
definately the 560kv is a much more powerful option..
TDRigid 2011
kmiglis is offline        Reply With Quote
Old 12-11-2011, 07:54 PM   #11
CACN
What pinion size do you have on the 560kv? I'm thinking a 13-tooth. Thanks!
Henseleit TDR, Helijive 120HV, HC-3SX, HKIII 4035 560KV
Minicopter Diabolo, Helijive 120HV, AR7200BX, Xera 4530 500KV
Align Trex 550, Beastx, 600MX
Hirobo SRB Quark
CACN is online now        Reply With Quote
Old 12-11-2011, 09:25 PM   #12
dswitkin
I run 13T on the HKIII-4035-500 and fly for 8 minutes at 1650 RPM on 12s4500 packs. With 14T you could probably govern at 1800-1850 RPM, and 15T will be a ton of power. Definitely do not use the 16T: either your headspeed will be insane or your throttle curves will be too low.
dswitkin is offline        Reply With Quote
Old 12-11-2011, 09:28 PM   #13
CACN
Got it. Thanks!
Hirobo SRB Quark
Old 12-12-2011, 02:50 PM   #14
kmiglis
when i was using 13t the whole drivetrain was more boggable on the 500kv but now whatever i throw at it just holds..
TDRigid 2011
Old 12-13-2011, 11:14 AM   #15
Dflyer
Thanks for all the input, i'll be trying the 4035/500 with the 15t pinion.
Grtz,
Dirk
Old 12-13-2011, 11:30 AM   #16
7.62x51
Today i had a couple of flights with this:
I'm using 13T pinion, after 8 minutes of light 3D still there 30% of charge in the 4000 mAh battery.
Fabio
Old 12-31-2011, 07:16 PM   #17
kimmik
while i dont have a tdr, i thought i'd answer the question regarding motor choice.
a 560kv bogs less than 500kv of the same model, only because the winding resistance is lower (from using fewer turns and larger gauge)
because you're running both motors off 12s, the 500kv will sag rpm more under the same load.
however, 560kv on 12s = 500kv on 13.5s, in all senses of the comparison - power, efficiency, durability, "boggability" etc (within practical tolerances)
kimmik is offline        Reply With Quote
Old 12-31-2011, 09:35 PM   #18
GabrielB1231
Yes, use the 15T, or use the 560KV and 14T. It will Work
GabrielB1231 is offline        Reply With Quote
