Go Back   HeliFreak > R/C Helicopter Support > SAB Goblin 630/700/770
SAB Goblin 630/700/770 SAB Heli Division 630/700/770 - Goblin Helicopters Factory Support
Old 12-13-2011, 06:45 AM   #1
ragge1
Default Pinion / Ratios
can someone please try to make me understand this
The ratios possible are:
Pinion 15 = r 14.3
Pinion 16 = r 13.4
Pinion 17 = r 12.6
Pinion 18 = r 11.9
Pinion 19 = r 1.3
Pinion 20 = r 10.7
Pinion 21 = r 10.2
Pinion 22 = r 9.7
Pinion 24 = r 8.9
Pinion 26 = r 8.3
Pinion 28 = r 7.7
| Atom 6HV : vbar NEO pro rescue | Goblin 700 : vbar 5,3 pro | HD Cell 500 : vx1e |
ragge1 is offline        Reply With Quote
Old 12-13-2011, 06:49 AM   #2
desertstalker
Pinion 15 = r 14.3
Pinion 16 = r 13.4
Pinion 17 = r 12.6
Pinion 18 = r 11.9
Pinion 19 = r 1.3
Pinion 20 = r 10.7
Pinion 21 = r 10.2
Pinion 22 = r 9.7
Pinion 24 = r 8.9
Pinion 26 = r 8.3
Pinion 28 = r 7.7
What about em? They are just geartrain ratios, take motor RPM divide by ratio gives mainshaft RPM.
-DX8
Old 12-13-2011, 07:51 AM   #3
geekindenial
This is a little table I made with Excel showing different headspeed you can get with different pinion and motor kV combos.
I'm going for a 520kV motor.
geekindenial is offline        Reply With Quote
