Closed Thread
Old 12-16-2011, 08:37 AM   #1
rightto360
Default What do you guys think of this?
The last flight that I did with my Trex I was getting really poor tail control. When I landed I discovered that the tail was coming apart.
In the attached photo it appears that the blade grip on the right will not tighten down all the way. I checked it and the bolt is tight. I am thinking that I may have a buildup of threadlock in there. Anyone got any ideas of how I can get it out?
The left grip is coming off the bearing. This was assembled for me when the kit came so I dont know what to do to repair it.
I am getting christmas leave and would like to get it back in the air over the holiday. Any suggestions would be appreciated.
Derrick
ID:	274010   Click image for larger version
Derrick
TREX 450 Pro
Futaba 9CAP
rightto360 is offline
Old 12-16-2011, 09:11 AM   #2
texasclouds
Take it all apart and make sure the bearings haven't separated. It is a simple design, download the manual from Align's website to see the breakdown diagram.
If you want easy button, just buy a new assembly:
http://www.clubheli.com/450PRO-Tail-...ps_p_3477.html
texasclouds is offline
Old 12-16-2011, 09:12 AM   #3
Bob O
Wow, you were very close to disaster there, glad you got it down before that grip let loose!!
If it was mine, I'd buy a new tail hub, bearings and screws. Or the whole assembly. This time, disassemble it, clean any locktite that might be on there, and reassemble with blue (med strength) thread locker.
Seems this part is hard to find. Here's an eBay link if you're so inclined.
BTW, I've never ordered from HeliPal. ReadyHeli and others were out of stock on it.
Good luck!!
SPARTANRC - Forum Support
Warp360
Bob O is offline
Old 12-16-2011, 09:29 AM   #4
texasclouds
I can vouch for the club heli parts being nice. Be sure to oil the bearings and blue loctite the screws.
$10 gets you this: Includes Tail Blade Grips, Center Hub, Bearings, Spacers Set Screw, Blade Screws and Nuts
Old 12-16-2011, 11:44 AM   #5
WNCmotard
I'll second clubhelis parts, and great service too.
Lawn darts have really changed since I was a kid, they now come with a remote.
Blade mCP X - brushless / Blade 130x beta / T Rex 450 Pro - 3G FBL, RJX head, KBDD tail blades / T Rex 600N LE in progress
WNCmotard is offline
Old 12-16-2011, 11:56 AM   #6
trexpro
Derrick
Hi Derrick,
Watch this http://helifreak.com/showthread.php?t=360680 i had the same problem
Danny
We Men Need a Second Hobby, Besides Women
Futaba T14SG, Vbar 5.3 pro, Kontronik, Align, Turnigy
Mikado, Scorpion, BeastX V3, Genius, Devo 7, Hyperion
www.modelhelicopter-review.nl
trexpro is offline
Old 12-16-2011, 12:47 PM   #7
texasclouds
sounds like some bearings will do ya. manual page 12 calls for 2x5x2.5mm and 3x6x2.5mm for each grip
note: this is a big file:
http://www.heliproz.com/images/Trex450ProManual.pdf
Align Bearings 2x5x2.5mm (4)
AGNHS1033 $5
Align Trex 450 Bearing 3X6X2.5mm (4)
HS1030 or MR63ZZ $5
Closed Thread
