Go Back   HeliFreak > R/C Electronics Support > Electric Motors, Gearing, Speed Controls, Gyros, Receivers, and Other Electronics Discussion
Electric Motors, Gearing, Speed Controls, Gyros, Receivers, and Other Electronics Discussion Electric Motors, Gearing, Speed Controls, Gyros, Receivers and Other Electronics Discussion
Old 12-18-2011, 05:27 AM   #1
OYLORE
Default Turnigy dlux 160A HV Brushless Speed Controller (OPTO)
Have anyone tryed this Turnigy dlux 160A HV Brushless Speed Controller (OPTO) in an T-Rex 700?
I´m waiting on my ICE 120 from sevice, but thing take times..........
OYLORE is offline        Reply With Quote
Old 12-28-2011, 08:59 AM   #2
Flippin Blades
Yes, i have this ESC. I use it to temporarily replace my CC 120A HV while its being repaired but i think i'm keeping it! It works really well. I am going to try the governor mode next time. Check out the compiled test video.
Flippin Blades is offline        Reply With Quote
Old 05-15-2012, 04:13 AM   #3
memini
Originally Posted by Flippin Blades View Post
Yes, i have this ESC. I use it to temporarily replace my CC 120A HV while its being repaired but i think i'm keeping it! It works really well. I am going to try the governor mode next time. Check out the compiled test video. http://www.youtube.com/watch?v=ib_ud...KbBnIHnpmcSV4v
What timing do you used on your 700E motor?
memini is offline        Reply With Quote
Old 11-14-2012, 07:00 AM   #4
DALE-PABAJO69
memini,I set my DELUX 160a on medium timeing,but I'm not sure it might work for you?
you can see in the photo I have the turnigy SK3 HELI-DRIVE MOTOR T 700 560KV wich is a 10 pole motor.
I still need to test fly at this setting it may need some changes.
DALE-PABAJO69 is offline        Reply With Quote
Old 11-18-2012, 08:39 AM   #5
satgod
have you tried pulling the data logging from it
i've been curious as to how well it actually performs and if the logging is any good
i'm actually leaning to the YEP 120hv's (YGE clone) but I like the data logging features like castle has
Trex 600EFL Pro V2 V-Bar ds610 ds650 cc pro bec Scorpion 130a HV KDE 600XF-530
450pro 1860kv(6s) cc50 (4 DS215MG) 10t pinion, Tarot DFC, Ikon
TBS Discovery (Quad), naza-gps, 900mhz fpv, gopro2, ET OSD pro, D/L UHF
X-8 Wing , D/L UHF Full fpv package
satgod is offline        Reply With Quote
Old 11-19-2012, 06:54 AM   #6
DALE-PABAJO69
satgod, my adivce go with the ype 120hv or the hobbywing 120hv (k-force) at least the k-force can be programed via PC and I assume that it should have more paramters to choose from and can be firmeware upgraded.
the turnigy dlux works fine but manual is a little confuseing and w/ programbox does not offer many options.
I need to reset my parameters my first test hover the esc got very hot but this is due to my assuming settins wich I was not sure how to set from the start.
BTW how is that ZYX 3 Axis working out on UR 600?
I've alway's been curious abut that gyro
