Go Back   HeliFreak > R/C Helicopter Support > ELY.Q - Vision 50
ELY.Q - Vision 50 ELY.Q Vision 50 Helicopter Support
Old 12-20-2011, 06:59 PM   #1
wifeorheli?
Default ElyQ Vision 50 V2 Tourqe Tubes
Hey guys well im happy to say ElyQ has has fixed another somewhat issue very quickly. i recently ordered two new tourqe tubes and they were different then the ones that came with the original build. The original build the TT End was attached by means of a rod with two cir clips on each end. The rod running threw them. Now i didnt notice the problem that was gonna arise from this being like that. I had two crashes both hitting the tail the TT gears stripped as usual but i noticed alot of play on the tube. Upon dissasembly i noticed the holes on the actual TT itself had widened. This was no good. Its was creating major slop. Old style shown in picture below V1.
As you can see above part numbers 10,11 are what was used to attach the pieces together. At that point is where the slop was occuring. Below is a picture of new V2.
Above is the fix. This is FANTASTIC. This will now be a slop free tube. And it now also comes with a bearing. Thank You ElyQ. Anyway the new tubes are availuable threw RcHeliWorkz.com just click this link here http://www.rcheliworkz.com/product.asp?specific=118077 tourqe tube shown in piture is the old one.
Team RcHeliWorkz.com / Team ElyQ USA
TeamRcHeliWorks.com / Team Novarossi / Pulse Lipos
wifeorheli? is offline        Reply With Quote
Old 12-23-2011, 04:04 PM   #2
tomd27858
ElyQ is definitely paying attention to any issues found and addressing them quickly.
Team HeliDirect
Skookum Support
Flying Align, controlled by Skookum, and powered by Pulse
tomd27858 is online now        Reply With Quote
Old 12-23-2011, 05:23 PM   #3
wifeorheli?
+1 TOM this is not the first time. I wish there was a dedicated list of all the v2 stuff.
Old 12-28-2011, 05:04 PM   #4
scottishlad
This is very nice. So easy too install. So far the kit is going together a treat .
scottishlad is offline        Reply With Quote
Old 12-28-2011, 07:57 PM   #5
wifeorheli?
very good to hear SCOTTISH if you need anything let me know. Make sure you take the time aligning your clutch stack. Also Set the mesh very TIGHT to the high side of the gear it will wear in over the first few flights.
