Go Back   HeliFreak > R/C Helicopter Support > Outrage RC
Outrage RC Outrage RC - and XP Li-Po Factory Support Forum
Old 12-22-2011, 01:03 AM   #1
lazsyss350
Default Outrage fbl head on a trex 600n
I want to purchase an outrage fbl head and install it on a 600n, it seems simple enough but i was wondering about the shaft that comes with the kit, do i have to use the main shaft they provide or can i continue to use the align shaft?
http://helidirect.com/r50n575-outrag...is-p-11264.hdx
lazsyss350 is online now        Reply With Quote
Old 12-22-2011, 01:47 AM   #2
willlig756
You can use the align main shaft it works good
A Main Hobbies/ProTek R/C Field Rep
RotorWorkZ ):>
willlig756 is offline        Reply With Quote
Old 12-22-2011, 02:12 AM   #3
lazsyss350
Cool thx
Old 01-19-2012, 10:22 AM   #4
texasclouds
how did this work out for you?
texasclouds is offline        Reply With Quote
Old 01-19-2012, 10:40 AM   #5
lazsyss350
Great, went together smoothly, looks awsome and flies great. the head i got is identical to my fusion.
Old 01-19-2012, 10:44 AM   #6
texasclouds
Stock align swash? Did you have to change any balls or servo horns?
Old 01-19-2012, 10:57 AM   #7
lazsyss350
Yep, stock align swash, shaft, and balls, as for the servo horns I did change those out for the align servo wheels that have the inner holes. I'll post up some pics later when I get home.
Old 01-19-2012, 11:09 AM   #8
texasclouds
thanks...I've been shopping for a FBL head and I think this Outrage 50 might be the one!
Old 01-19-2012, 10:02 PM   #9
lazsyss350
here are the pics, sorry there not the best.
Name:	trex 600fbl nitro 003.jpg
ID:	282215   Click image for larger version
Name:	trex 600fbl nitro 004.jpg
ID:	282216   Click image for larger version
Name:	trex 600fbl nitro 006.jpg
ID:	282217   Click image for larger version
Name:	trex 600fbl nitro 001.jpg
Old 01-20-2012, 07:35 AM   #10
texasclouds
Cool, that looks nice. Silver blade grips/swash and black in the middle.
I got an offer on my Quark gyro. Hopefully someone will bid on my 600FB head as well. Then I'll have some coin to put down on a new FBL setup
