Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > Outrage Fusion 50
Outrage Fusion 50 Outrage Fusion 50 Electric Helicopter Factory Support Forum
Old 12-22-2011, 02:37 AM   #1
Kaveeth
Default What ESC should I use???
Ok so i'm looking at getting a Fusion 50. I've pretty much got all my electronics sorted out, except for the ESC.
I'm planning on running a 12s setup so which esc should I use?
Is it safe to use cc ice2? I can't really justify buying a jive, so maybe hobbywing?
Any help would be appreciated
I could fly so much better if the ground wasn't there.....
Goblin 700 | SK540
Fusion 50 | SK540
Kaveeth is offline        Reply With Quote
Old 12-22-2011, 02:39 AM   #2
AnTi Taco
get what u can afford i run a CC ice 80hv V2 but the hobbyking HV ESC is also a good option
Compass 7HV 9180/9188 Vbar
Compass 6HV 9180/9188 Skookum,4025-630KV
Compass 6HV Savox/ 9188, Vbar,
Fusion 50 9080/9088 Beast X
Velocity 50n 9080/9088 VbarSAB Goblin 9180/9188 Kontronik helijive Coming soon
AnTi Taco is offline        Reply With Quote
Old 12-22-2011, 02:42 AM   #3
Kaveeth
i'm a bit reluctant about using cc after all the reports of fires. I heard that the ice2 didn't really fix the problem. Is this true?
Goblin 700 | SK540
Fusion 50 | SK540
Old 12-22-2011, 02:53 AM   #4
Carapau
To find a properly balanced argument on the CC line of ESCs is pretty hard at the moment. Another one to consider is the YGE. From what I understand the YGE and HW work really well with external govs such as on the Vbar. Scorpion have just released the Commander V 50V which looks really neat especially as it is pre wired for external govs. The Scorpion has really twigged my interest I must say.
Logo 700, Logo 600, Forza 450EX, Trex 470L, Jeti DS-16, couple of planks and lots of laughs
Carapau is online now        Reply With Quote
Old 12-22-2011, 03:25 AM   #5
Wh1teAfr1can
I haven't heard any reports of the new ones burning except for a guy running a severely over geared 700 on a 120 with current limiting turned off.I am running an ice hv 80 on 12 s and its perfect
Richard Zappe
Team Manager Kontronik USA Team minicopter
Diabolo Kosmik 200, Pyro 750 - 50 Comp, Diabolo S #RZ, Diabolo 550 Jive Pro 120, Pyro 650-103 Comp
Wh1teAfr1can is offline        Reply With Quote
Old 12-22-2011, 03:49 AM   #6
Kaveeth
Even so, I think I'll go with a hobbywing. Will the 70hv work ok or should i go for the 100hv
Goblin 700 | SK540
Fusion 50 | SK540
Old 12-22-2011, 04:20 AM   #7
Geffect
It will depend on your motors current draw. What motor are you using?
Geffect is offline        Reply With Quote
Old 12-22-2011, 04:51 AM   #8
Kaveeth
either the stock outrage motor that comes with the kit or a scorpion 4025-550
Goblin 700 | SK540
Fusion 50 | SK540
Old 12-22-2011, 06:41 AM   #9
hndaluvr
Hobbywing is a good choice... but I would get 2 of right off the bat. They have their issues with burn-up also (usually upon initial install, first spool up, they may blow). If you get past that... they work beautifully. You're pretty much assured a good one out of the 2.
hndaluvr is offline        Reply With Quote
Old 12-22-2011, 07:16 AM   #10
Joe Bailey
I have a YGE 90hv in mine, it even has a built in phase sensor for the vbaaaaaar gov as well.
Don't forget to price in a bec when looking at kontronics price, almost all escs need an external BEC to power the system but the kontronic one can cope with flybarless helis.
Joe
I'm not controlling it, I'm just preventing it from crashing.
Joe Bailey is offline        Reply With Quote
Old 12-22-2011, 09:04 AM   #11
Chris Sexton
I have CC ICE2 ESCs on all of my birds, save the X5, and I haven't had any problems. i did read one report of an ICE2 120 burning up but that turned out to be a bad motor/esc pairing. Some of the newer 45 and 50 series motors MUST have 160+ and I think he was trying to get buy on a 120.
That being said, i have to agree with the others, the HW and YGE are great options. If I had the money, I would run Kontronic on ALL my birds, but even adding a good BEC, they KONTRONIC is WAY more expensive than the HW and CC units.
AS for your question about size, I run the 80A with my Outrage 4125-560 motor and I haven't seen a sustained amp draw over 60, peaks yes, but sustained no. I would think the 70HV would be enough, but if the cost difference isn't a deal breaker, get the 100 just to be safe.
Synergy Factory Specialist / Rail Blades / Team Scorpion
Chris Sexton is offline        Reply With Quote
Old 12-22-2011, 10:09 AM   #12
Slyster
I use the Jive 80HV. Best esc governor out there and best BEC as well so no need for flight packs or external BEC. And of course rock solid quality etc.
"It's not just a hobby... it's a lifestyle" - Pete ϟ
Slyster is offline        Reply With Quote
Old 12-22-2011, 10:13 AM   #13
hndaluvr
Kaveeth,
Oh yeah...forgot to ask.... will you be running an external gov.?
If NOT, the HW 70HV (Platinum) is the one to get. If you go with the 100HV (Pentium series) it DOES NOT have the internal gov that the Platinum series DOES. The Platinum series gov works pretty well too... sure it's not on-par with say... VBar or Kontron... but it works every bit as well as the CC.
Just things to consider....
Old 12-22-2011, 01:13 PM   #14
dantemcc
I'm wondering about this as well. I have 80hv v2 for mine and im hesitant to use it cause of the fire concern. I run a hw120 on my 700e and a 70hv on my 600pro and love em both and have had no issues as of yet. So I'm debating if I should just sell the 80hv and just get another 70hv. But Castle did state, if it catches on fire, send it back and they'll give you a free one.(ROLLING MY EYES WITH A PASSION)
https://www.youtube.com/channel/UCVA...MiyWkC_3r0vjMw - Me And MineTv Coming to Youtube Winter 2015
dantemcc is offline        Reply With Quote
Old 12-22-2011, 01:37 PM   #15
hamstar78
Im using hobbywing hv 70 with no issues. Works great
Trex 700n
hamstar78 is offline        Reply With Quote
Old 12-22-2011, 04:39 PM   #16
Kaveeth
Originally Posted by hndaluvr View Post
Kaveeth,
No I don't plan to run an external gov so I guess I should go with the 70HV then. I'm gonna put a beastX fbl unit on it, at least at first, so having a governor in the esc would be good.
Goblin 700 | SK540
Fusion 50 | SK540
Old 12-22-2011, 08:35 PM   #17
mtymyk
+1000
Team Rotorquest/ SAB Heli Canada
mtymyk is online now        Reply With Quote
Old 12-24-2011, 08:28 PM   #18
Bubble Head
I too am considering a 70hv for my fusion.... I'll be running either the outrage motor or the 4025-550 as well as a cc bec.... Still cant decide on the esc...
Merry Xmas btw
Fusion 50 FBL
Trex 450 pro
DX7s
Bubble Head is offline        Reply With Quote
Old 12-24-2011, 10:18 PM   #19
Kaveeth
yeah, bubble, thats exactly what i'm doing too!
Goblin 700 | SK540
Fusion 50 | SK540
Old 12-24-2011, 10:31 PM   #20
snowball75
Go with a 70hv. They are stock on a compass 6hv. Runs great with fbl units like a vbar or skookum. Invest in a 2 in 1 program box so that you can upgrade to turnigy's 1.07 firmware that enables better slow starts.
If you want to spend more money, yge makes great escs. And the scorpions look nice also.
But my money would be spent on a 70hv then use the savings on a 9188 tail servo.
Sent from my Desire HD using Tapatalk
snowball75 is offline        Reply With Quote
