| Scorpion ESC and Motor Support Scorpion Power Systems ESC and Motor Factory Support Forum |
Can I use the 2221-8 as a generator?
Dont see why not, you will need something to deal with the 3 phase AC you will get from it though. A BLDC motor and a 3 phase AC generator are pretty much exactly the same thing, only issue I can see is spinning it too fast and generating voltages it was not designed for. the Kv should give you an idea of what voltage you will get out for a given RPM.
-DX8 -MSH MiniProtos Stretched, SK720, DS95/DS95i, Hyp 4S 25C 2500mAh -MSH Protos Stretched, Brain, Hyp DS16/BLS251, 6S 3000mAh |
So what should I do to it if it will be putting out AC instead of DC? Also how to wire the motor to my output cause the motor has 3 wires? is the power gonna be on all three wires or just two?
#4 | |
There is a guy on the Gasser forum who makes generators for helis, perhaps they can help. This will help with the rectifier http://www.allaboutcircuits.com/vol_3/chpt_3/4.html
