| mSR X Blade Micro SRX Helicopters Information and Help |
I was just wondering if anyone has broke theirs yet, and if so what was it? Mine is still in one piece and I have had several hard crashes. The only damage I have done is a small crack in the canopy and a piece of scotch tape fixed that real quick.
I broke one of the blade grips. Managed to snap the little ball joint off. Pulled a grip off my msr and was good to go again.
Team Synergy VP Racing Fuels Team Scorpion |
+3
Hard crash into the wall separated the link from the blade grip.
BL mCPx (HP05 motor/SR120 tail), Blade mCP X v2 (stock), Blade 130X, Blade mQX Blade mSR X, Blade mSR, Blade mCX2, Blade mCX, Blade Tandem DX8, Phoenix Sim, AMA# 976697 |
Ill follow the trend and i snapped the balls off both blade grips in one crash.
#6 |
Balls off blade grips, boom one time only, fly solid rod now and posts on frame.
#7 | |
-Don |
#8 |
#9 |
#10 |
One side of blade grip broken after hitting ceiling fan......got plenty Msr replacements thank goodness!!!!
#11 |
Well i have a thread asking if anyone has tried MH blade grips on this thing as i feel i need to order 3-4 spares and for that its cheaper to buy the MH blade grips.
Other than that this thing is just as bullet proof as the old mSR is. The skids they use which always were weak on the mSR are just MCPX skids with a small battery holder. Those wont break, and if you put a solid CF boom on the tail it should be even harder to break. After the blade grips i have a feeling the swash will be the next weak spot, We will be stuck buying stock ones until MH gets some produced. |
#12 |
My HF Map location Join Date: Nov 2009
Location: May no longer be in Black Forest. Now in Parker CO!
No crash, no break.
MH (Gold) MCPX BL MH (Gold) NCPX Blade NCPX Future HeliMax 1/43 Eurocopter owner! DX7. Rakon Rep. |
#13 |
my motor quit but will spin if i over ride it manually.
#14 |
Tail rotor from a hard tail strike.
#15 |
Another couple of blade grip balls broken off. In flight both times.
Trex 450 mutt, Trex 450 Pro, Trex 550E 3G, MaxiR, Most of the Blade mSeries.. |
#16 |
1 ball off blade grips.
#17 |
Broke blade grip on one side on 15th or so flight. Still can't get enough... Do i need to buy another msrx or wait for replacement parts to start showin up?
#18 |
Msr blade grips will fit.
#19 | |
Not really sure why it has a different part number - mSR vs. mSR X.
#20 |
Burned up a tail motor but it was an abuse factor ... over 70 cells in 3 days with almosr no cool down. My fault.
Sent from my DROID RAZR using Tapatalk
JR 9503X/DX6i/CX2/MSR/MSRX(X2)/Mcpx/T-Rex 450 Pro V2 3GX/T-Rex 550e 3g/ Ember 2/ T-28D Trojan/ AMA# 970122 |
