Old 05-23-2007, 11:09 PM   #1
helijj
Default Which Neu for my 600
Well I made a order of a Medusa 36-50-1500 and thank GOD that it was out of stock, because I receive a email from Jim and wrote to me that this engine is not good for hard 3D. that they are making a better one. So I told them to refund me the money back.
So the only choice is Neu. I am only going to run 6s lipos no more than that. Which Neu will be the best for me?
I heard about the NEU 1910/1Y with fan , other Neu 1.5Y? I really don't know the difference about one or the other.
helijj is offline        Reply With Quote
Old 05-23-2007, 11:25 PM   #2
jT415Gz
The top motor right now on 6S would be the Neu 1515/2.5D/F but you may need a better ESC like one of Castle Creations. But again I am not definitely sure. Read about more in the forums.
-jT *Closed mouths don't get fed*
Trex 500, Trex 600N, Avant Aurora
jT415Gz is offline        Reply With Quote
Old 05-23-2007, 11:27 PM   #3
jT415Gz
http://www.helifreak.com/viewtopic.php?t=37766
Old 05-24-2007, 09:41 PM   #4
erniefritz
Helijj - check the sticky at the top of the forum that reads "power systems that work" for me , i run 6S only and am running the NEU 1515/2.5D/F , it gives great power thruought the flight and stays cooler than the other motors. you can use the stock ESC , but i suggest that you upgrade the ESC if your going to be pulling hard on the motor , just piece if mind. The Castle Creations Phoenix 125 is a great choice , i've also used the CC phoenix 80 , both on this NEU motor... It's hard to beat this motor with a 11T pinion or 12T helical pinion and a 100% throttle curve for idle-up and +- 13 degrees pitch make this setup the best 6S setup IMHO.... :glasses2:
erniefritz is offline        Reply With Quote
Old 05-24-2007, 09:48 PM   #5
helijj
great erniefritz!!! So what is your flying time compare to the stock motor?. Also I see that on motor description some says W/ fan, Fan, 1.5, 5Y. What all that means?
Old 05-24-2007, 10:17 PM   #6
helijj
Ok., I just found this 2 Neu motor for the same price. What is the difference from one of the other?
NEU1512/1.5y
NEU 1515/2.5D/F
Old 05-25-2007, 07:49 PM   #7
erniefritz
the difference is the KV rating on the motor which means the motors have different windings inside... also the 1512 is a smaller motor than the 1515 series. you want the 1515/2.5D/F :wink:
You won't be sorry, it's a great motor with lots of power , flying time depends on your flying style , but this motor is a little more efficient than the 600L.
F = finned , not fan , these motors are inrunners , the stock motors are outrunners in a can. the fins on the inruner help dissipate heat more effectively. :wink:
Old 05-25-2007, 08:02 PM   #8
Mercuriell
http://www.neumotors.com/20061222/15...es%20data.html
Model RPM/Volt Volts Max Amps Efficiency Rm (Ohms) Kt (in-oz/amp) Io
1512/1.5Y 1900 8-32 80* 90+ 0.009 n/a 1.8
1515/2.5D 1700 7-35 80* 90+ 0.010 n/a 2.25
John
Mercuriell is online now        Reply With Quote
Old 05-26-2007, 04:55 PM   #9
helijj
Mercuriell that is great info you just gave me, Thank you!!. But I am a newbie in electric heli, and expert in nitro. You guys had help me of the motor definition. But What is the benefit that I can take out of this Volts, Amps, Efficiency Rm, etc. etc? Think that If I am a beginner (that I am) lets take a class of "Electric heli 101" and I have to chose for a motor, Bec, etc. What do you guys look for? How do you know which is the best combination in bec, and motor etc. etc.? How do you understand this graphics?
