Go Back   HeliFreak > R/C Electronics Support > Castle Creations ESC and Software
Castle Creations ESC and Software Castle Creations ESC Software and Hardware Support
Old 12-24-2011, 06:30 PM   #1
sacko
Default Using a Buffer Pack on a CC 120 ICE2
Anyone doing it?
I have read mixed reviews about doing it, but I need some sort form of backup.
I have also looked at running a LiFe 900mah buffer pack opposed to Ni-Cd; anyone done this before?
I will be using a Gryphon 7075 BEC.
Trex 500ESP - Vbar v5, MKS 9660A, BLS251,
Outrage Velocity 50 - Vbar v5, Futaba BLS 351, Outrage 9080, OS55 all @ 8v
Kasama Srimok
sacko is offline        Reply With Quote
Old 12-25-2011, 06:42 AM   #2
kcordell
Buffer pack? Do you mean a separte RX pack to power the servos?
Team Futaba, Team Miniature Aircraft, Team Flightpower, Radix Blades, VelTye, YS Engines
kcordell is offline        Reply With Quote
Old 12-25-2011, 07:24 AM   #3
sacko
A Nicad/Nimh pack that is plugged into the Rx if the ESC or BEC gives up; at least you will still have cyclic control to auto it down.
The Nicad is charged by the BEC. This comes as standard with a Kontronic setup.
Kasama Srimok
Old 12-25-2011, 04:55 PM   #4
kcordell
Sounds like too much going on. Eliminate the BEC and run a straight RX pack.
Much easier to deal with and if flight batteries give way, you still have complete control, less motor.
