Old 03-13-2012, 02:16 PM   #101
im2tall
Now I'm excited I want one!!
im2tall is offline        Reply With Quote
Old 03-13-2012, 09:02 PM   #102
lcc014
Originally Posted by Aleusius View Post
Hi Ching-Ho,
I know you would be first....
Caren
No, I don't think so because I am working on my FBL 250 right now using ZYX gyro. I will put on the TT kit when the FBL 250 is flying ok
Nano CPx, Hirobo Quark
250 SE, Pro Upper Frame, Talon25, KDE, KST215, DS95i, Mini Vbar
450 Pro (6s), KDE, Lynx, Tarot, RJX, YEP40, KST215 & 515, SK540
465 (6s), Align DFC, HW50AV3, KST315 & 8910A+, SK720BE
Warp 360, Scorp 1360KV
lcc014 is online now        Reply With Quote
Old 05-24-2012, 05:46 PM   #103
Aleusius
Hello,
so far, mine is done. Runns very smooth and very easy...
Caren
Name:	250 starr.jpg
Aleusius is offline        Reply With Quote
Old 06-07-2012, 12:34 AM   #104
eerie
I just ordered mine. Found out about it on infinity Site. Anything to watch out for during the assembly? I hope this will reduce my tail wag.
T-REX 450 SE MD500 (SE-maiden 15/03/06) (XL-maiden 16/10/05)
T-REX 500 ESP (maiden 25/09/2010)
Flasher 250 (maiden 13/09/2010)
RAPTOR 50 TITAN (maiden 16/06/2006)
eerie is offline        Reply With Quote
Old 06-07-2012, 01:17 AM   #105
walkera4g3
don't forget you have to use glue, a strong glue
walkera4g3 is offline        Reply With Quote
Old 06-07-2012, 02:34 AM   #106
noddyflyer
make shure you glue the gear on the tail shaft (i forgot and the tail shaft pulled out of the bearing)
t250se 3blade head]t 250se fbl 250spmotor ,hitec 65hb cyclic gp780 giro mks 480mg /t250pro 250mx motor savox 257mg align g31 /ds 480mg tail/alzrc devil 450,kst 115mg cyclic/ds520 tail turnigy typhoon motor/yep 45a esc /dx8...my flying ability
noddyflyer is online now        Reply With Quote
Old 06-12-2012, 05:17 AM   #107
eerie
Do I use CA or 5min epoxy?
Old 06-12-2012, 09:39 AM   #108
noddyflyer
ca should do it (ive only had a couple of flights on mine since) epoxy is a bit messy for me
Old 06-12-2012, 06:55 PM   #109
walkera4g3
I've known people that has used CA and it didn't last that long. something to think about
Old 06-12-2012, 11:52 PM   #110
eerie
I tried to do the conversion last night. Didn't manage to finish it, turns out I need to upgrade the tail case too. Old tail housing can't fit the 2 gears
Old 06-13-2012, 08:02 AM   #111
noddyflyer
i got a threaded tube (copter x one )that goes in the boom holder and cut it to length ,works a treat ...mick
