Go Back   HeliFreak > R/C Helicopters > CAD/CAM
CAD/CAM R/C Helicopter CAD/CAM
Old 01-14-2012, 03:53 AM   #21
Cirkus
You will only get this one to cut about 28x43cm
FlightCam
http://ryanbarnes.smugmug.com/
Cirkus is offline        Reply With Quote
Old 01-19-2012, 07:38 AM   #22
Azalin
OK i have the mechanic parts on the way. Max working area will be something like 60x50 cm. Decided for 16mm shafts for x axis and 12mm for others. Not sure if the Y axis will work with 12mm shafts but well see.
Suat
Trex 700 Gasser
FBL | HeliBug HB7-RC 17T | Silverline V-Bar| TRM VX290TT | SG | RJX Gas muffler (modded)
Trex 600 Gasser FBL | HeliXHeli conv. | OS GT15HZ | iKon | Homemade onboard generator
Azalin is offline        Reply With Quote
Old 01-19-2012, 08:38 AM   #23
Cirkus
That's pretty small. I have a smaller machine and I have 20mm rods. You may get some flex in it. The Y axis should have the larger rod, since that will be your longest side.
FlightCam
Old 01-19-2012, 11:04 AM   #24
Azalin
Do you think the rods on X axis are fine? They are 16mm
Suat
Trex 700 Gasser
Old 01-19-2012, 11:14 AM   #25
Cirkus
My x axis rods are also 16mm (5/8") but are shorter than yours. Mine are 12" and your's are about 19" so you will inherently have more flex. The longer the rods, the thicker diameter you will need to counter flex. Also the distance between the 2 X axis rods makes a difference. Spaced wider is better, closer is less ability to counter tool deflection. It's all a trade off but I think you will be OK as long as you are ok with having to slow your cut speed down to prevent flex.
FlightCam
Old 01-19-2012, 11:19 AM   #26
badfrog
Originally Posted by Cirkus View Post
My CNC router will be here Thursday...anybody want a build thread?
PLEASE!!!!!
badfrog is offline        Reply With Quote
Old 01-19-2012, 11:22 AM   #27
Cirkus
Originally Posted by badfrog View Post
PLEASE!!!!!
http://www.helifreak.com/showthread.php?t=374453
FlightCam
Old 01-19-2012, 11:52 AM   #28
Azalin
Yes I was thinking the same. At least for the very first version. I can change it in time if i needed. Thanks.
Suat
Trex 700 Gasser
Old 01-27-2012, 08:09 AM   #29
cd_edwards
just finished building my cnc router. It's a little larger at 4ft x 4ft of cutting area. I purchased my parts from CNCrouterparts.com. That cheap controller you might want to replace soon as they are not very reliable from what I understand.. Suggested replacement is a geckodrive G540. On CNCZone there is a thread by romanlini about some Hall-effect limit switches which would be a good first project for you.
ID:	284092   Click image for larger version
600N, DS760, 500ESP vbar 5.0pro, 450SEV2 DS-760, 450Pro vbar 5.0pro, 250SE vbar 5.0pro
MAAC 43005
cd_edwards is offline        Reply With Quote
Old 01-27-2012, 09:35 AM   #30
Cirkus
Actually, the enclosure they build is very well made. Obviously, not on the level of popularity of a gecko, but I would say from what I've read the trouble most people have is not knowing which end of a screwdriver to use...by that I mean end user error. Especially when people get to wiring and building themselves.
FlightCam
Old 01-27-2012, 09:46 AM   #31
badfrog
Nice looking setup CD! with a 4' by 4', any issues with flex? what plans did you use to build it?
Old 01-27-2012, 08:33 PM   #32
cd_edwards
I used the CNCRouterparts.com plans. So far I'm still testing. There really doesn't seem to be alot of flex so far but then I've just finished building it. I broke a 1/8" bit instantly when I forgot to start the router and started the cutting run for a case for a hall effect sensor. My upper gantry is made from 3060 aluminum extrusion which is pretty beefy. The gantry supports are steel.
MAAC 43005
Old 01-29-2012, 12:25 PM   #33
Azalin
Thanks.
One another question about bushing blocks. What do you think of these?
http://www.goodluckbuy.com/rectangle...ocks-lg25.html
Suat
Trex 700 Gasser
Old 01-29-2012, 08:32 PM   #34
vtcnc
Default Solidworks is a TON of money!
Solidworks is all you need.
Solidworks is ALOT of money for 2D frame profiles.
vtcnc is offline        Reply With Quote
Old 01-30-2012, 07:41 AM   #35
cd_edwards
Frankly my experience with goodlucksell has been dismal. Your mileage may vary. On another note, those are just the linear block and not the rail. Personally I'd keep looking
MAAC 43005
Old 01-30-2012, 07:45 AM   #36
Azalin
Yes. Those are blocks only. I will buy the rails from a local shop because goodluckb. have no 1m rails in stock.
I ordered a a shipment 2 weeks ago and payed EMS cost. They haven't shipped it yet.
Suat
Trex 700 Gasser
Old 01-30-2012, 11:29 AM   #37
Cirkus
Yeah, but he already has it that's why I said that. I agree, SW is a lot. Work just got me a copy of 2012 and it cost twice what my mobile workstation cost.
Also, even though you only need a 2D frame profile to cut it on a router, you have to build it in 3D if you want to assemble it into an entire heli and see how all your components will fit together virtually before you start making parts. This is where SW pays for itself.
FlightCam
Old 02-29-2012, 02:19 PM   #38
Azalin
I started to build mine.
ID:	294594   Click image for larger version
ID:	294595   Click image for larger version
ID:	294596   Click image for larger version
ID:	294597   Click image for larger version
ID:	294599   Click image for larger version
Suat
Trex 700 Gasser
Old 03-03-2012, 03:18 PM   #39
Azalin
The Y axis
Suat
Trex 700 Gasser
Old 03-06-2012, 03:04 PM   #40
Azalin
Suat
Trex 700 Gasser
