Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 450
Blade 450 Blade 450 Helicopters Information and Help
Old 12-28-2011, 02:51 PM   #1
72mhz
Default Link lengths from the developer
Some have had the same question as I did about the lengths of the links on the B450.
Well got this today and thought I'd share:
Hello Palmer,
Below is the response from Mikel Graham, the developer for the 450 3D.
Here are approximate values, but the videos should be explanation
enough.
Subtrim the control arms first until they are level, then adjust the
linkages.
Left swash link: 55.73 mm
Front swash link: 49.74 mm
Right swash link: 43.95 mm
Swash to main blades: 61.38 mm
Hope this may help someone else.
72mhz is offline        Reply With Quote
Old 12-28-2011, 03:01 PM   #2
Bananaslug
Very nice...
Bananaslug is offline        Reply With Quote
Old 12-28-2011, 03:07 PM   #3
DesJardins
That's pretty damn precise for ya!
Blade 450X & Blade mCPX BL
Spektrum AR7200BX
ProgressiveRC's "The Neutrino Ticket"
DesJardins is offline        Reply With Quote
Old 12-28-2011, 05:26 PM   #4
rotorwing cris
Great piece of detail info. for all blade users. Are left and right links as viewed from
the front of the heli or from the tail?
rotorwing cris is offline        Reply With Quote
Old 12-28-2011, 05:40 PM   #5
FuntanaS
Viewed from the tail looking toward the nose since the left servo is underneath the right.
Tarot 450 Pro V2 FBL - Blade mCP X - Blade 450 3D FBL
FuntanaS is offline        Reply With Quote
Old 03-04-2012, 09:33 AM   #6
buddha2490
I've seen this discussed but don't remember a definitive answer. How is one to measure these lengths? Total length end to end? Just the metal part showing? Middle of the link "hole"? Some other point?
Thanks!
Blade 450, Scorpion 2213-14 motor, Quark Gyro - cheapo blades
Blade MCPx V2 - Now Brushless!
buddha2490 is offline        Reply With Quote
Old 03-04-2012, 10:43 AM   #7
72mhz
I've been going from over all length, outside to outside of the links....gets you pretty close.
Old 03-04-2012, 10:58 AM   #8
buddha2490
Thanks!
Old 03-04-2012, 06:42 PM   #9
MaDDN3ss
Thalios should add these values to the bible. It may help someone one day.
Spektrum DX6i
E-Flite Blade MCPx (MH head, swash & grips)
Blade 450 3D FBL w/ Tarot Head + BeastX
MaDDN3ss is offline        Reply With Quote
Old 03-04-2012, 08:13 PM   #10
buddha2490
A link to this thread is in the bible.
Old 06-30-2012, 08:57 PM   #11
cpmboy
Hello Palmer,
enough.
linkages.
is this:
a. end to end?
b. center ring to center ring?
All begins (Jun 2011).......
Next project:
MSH Mini Protos, 450 Scale Airwolf, BAH Mini Quad
cpmboy is offline        Reply With Quote
Old 06-30-2012, 09:53 PM   #12
Skidpad
I measured mine as overall length with my calipers, and it worked out very well - within a few thousandths either way - and my swash ended up right around 15mm.
180CFX, Trex 550E (night), Goblin 570, Goblin 630C, DX8. Team Lynx Heli Innovations Pilot
Skidpad is offline        Reply With Quote
Old 07-05-2012, 02:36 PM   #13
TrEsPaSS
Noob here, what is meant by: 'Subtrim the control arms first until they are level, then adjust the
linkages.'?
TrEsPaSS is offline        Reply With Quote
Old 07-06-2012, 11:11 AM   #14
Belgarath
linkages.'?
I'm new too, but I believe the idea is to get your servo arms properly centered first, as you don't want to compensate for off center by changing link lengths. Making sure your transmitter is set correctly, you first physically remove the arm and put it on as close to center or level as the teeth will allow. Then you adjust your subtrim in the menus of your controller to fine tune it.
Sent from my DROID RAZR using Tapatalk 2
Belgarath is offline        Reply With Quote
Old 07-06-2012, 11:29 AM   #15
celltech
linkages.'?
Subtrim is a menu in your tx for getting your servo arms at 90. Trim is the switches around your left and right sticks to dial your bird in, assuming its a FB setup.
Trex 600efl Pro,Beastx, Blade 450 3D, ZYX Tarot FBL, Blade 450 3D stock, MCPX v2, Sr120, Spektrum DX8
celltech is offline        Reply With Quote
Old 07-07-2012, 12:17 AM   #16
cpmboy
1. Adjust the servos arm close to 90 deg as possible in relation to the main shaft. If a bit off, adjust using subtrim.
2. Set all 3 cyclic servos so that all move in the right direction...AIL/ELE/PITCH/TT
2. Swash levelling: use a levelling tool
Mid : adjust the linkages until the swash is level (flat horizontally). If just a bit off, use
subtrim.
Hi & Low : use Adv Travel
Next project:
Old 08-29-2013, 05:33 PM   #17
dchance
I just measured mine:
Left swash link: 2.16" overall/outside
Front swash link: 1.96" overall/outside
Right swash link: 1.72 in overall/outside
Swash to main blades: 2.47" overall/outside
2 parallel links connected to front servo: 2.56" center to center
dchance is offline        Reply With Quote
Old 09-01-2013, 11:09 PM   #18
Neunerball
linkages.'?
First to all others. Sorry for posting the URLs again. However, helped me a lot!
http://www.rchelicopterfun.com/swashplate-setup.html
http://www.rchelicopterfun.com/rc-helicopter-tips.html
"Nothing is as constant as changes"
DX9, DX6i, Blade Nano CP X, ZYX "Blade" 130X, Blade 180 CFX, Blade 230S, Blade 300X, Blade 450 3D (about 2 b FBL; have the parts, not the time), Blade 180QX
Neunerball is offline        Reply With Quote
Old 09-08-2013, 07:01 PM   #19
Gladius
subtrim.
Before you do any of that, disconnect your motor, hook up your battery, and set your collective to midstick. You need to level your swash at midstick, so you can set 0* pitch.
You also want to have a linear pitch curve for levelling your high and low travels. If your Throttle Hold pitch curve is not linear, either reprogram it for swash setup, or turn TH off (which is why you need to disconnect your motor!)
<> Trex 600 ESP FBL, Trex 500 ESP FBL, Gaui X3 <>
<> Builds in progress: Logo 600SX, KDS Chase 360 <>
*Spartan Vortex VX1e*
Gladius is offline        Reply With Quote
Old 07-20-2015, 12:59 PM   #20
technut
I was adjusting my mechanical and got all messed up. I needed to get linkage rod lengths to get back to normal. Helifreak is the bomb!!! Thank you to 72mhz and dchance for there great info.
technut is offline        Reply With Quote
