| Compass Model Helicopters Compass Model Helicopter Discussion |
Nankinhobby.com Field Rep Compass Support Compass Atom 500 FBL Compass Atom 6HV FBL Compass Warp 360 Gaui NX4 Check out my YouTube channel: thedaveyht3 |
Hadn't seen that image yet, thanks for sharing! And yes, the underside of the nose section is your battery compartment - would be nice to link to Sebastions post where he offers up some dimensions and hints as to the power configurations he has in mind. Also, important to note the intended blade sizes and AUW of the model.
6HV|Warp 360| Compass Models | Prostar Hobby | MKS | EP Buddy | Team KBDD |
42, D@mmit!
KBDD-Team Pilot Team Compass / ProStar Hobby Gens Ace Field Representative Warp 360, 7HV,Knight Pro,Knight 3D, Atom 500, Odin II, 6HV, 3D Plus, Knight 50 |
Really like that they angled the inner swash balls at 90 degrees - always wondered why no one did that....
Sweet little heli, as he says it's very mini-TDR ish.. I imagine the looks will be a bit love it or hate it lol.
Blade mCP X - Brushless, XP-7A, HP05S Gaui X2, BeastX/Scorpion 3400kv/YGE-30A/GS-093/DS95i Align AH-1 Cobra (T-Rex 500) Align T-Rex 600 EFL Pro, SK720/600MX/YGE-90HV/BL9180/BL9188 |
I just PM'ed you with a note and address. Please put my name in the hat as I'd love to try out the FBL system.
#6 |
Lots of TDR name dropping in the video. Don't forget the reason the TDR and mikado are so highly regarded. The parts, hardware, machining, and bearings are all the best quality you can get. You can copy the design elements and call whatever you come up with "TDR inspired" all day long. Once you produce the parts in outsourced machine shops located in 3rd world countries the quality of the machine is outside your control.
#7 |
I want one, but only with a fly bar or someone can donate a BeastX to me
Blade 130X Xtreme-Production
Blade mCP X (Bl) Blade Nano CP X Prôtos 700 |
#8 |
Did he mention the features are very TDR-ish?
#9 |
Maybe I'm crazy butim not a big fan of the TDR look. The frame and head look nice but I don't care for the skid and canopy style that much. Nice to see more selection either way though.
Compass Atom 5.5: AR7200BX, Talon 90 Compass Warp 360: AR7200BX, Lynx Blades |
#10 |
#11 |
#12 |
Kasama does the 90 degree swash balls ....
Goblin 770 4540 395 Sig 16S YGE 160UHV VBar (gov) Goblin 700 4530 540 LE 12S Ice 2 160HV VBar (gov) Brushless MCPX |
#13 | |
The WARP should't look to much like a TDR. In fact the only two similaritis are the the clamp for the struts and the swashguide. If you look to the diffrences, you can see its a unigue design. Some diffrences: Motor position: In the back not in the front Rotorhead: totally rigid, no swashdriver on shaft or centerhub Tailbelt: TDR use Torque Tube Maingear: TDR use 2 Step helical gear we use one step beltdrive. Aileronservoposition: Just compare it Canopyshape: TDR Canopy is closed in the rear. No Tailsupports: TDR use it. Carbon Tailcontrolrod: TDR has it on top of the boom. Radiotray: TDR in the rear - Warp in the Front Rudderservoposition: TDR in the rear - Warp in the CG. One Way Bearing: TDR straight on the shaft - Warp on a hardened sleeve. Compass Model use best quality bearing you get in the asia marked. Of course Compass could safe some money by using cheap bearings but compare the Compass quality of bearings to the quality the German brands use - its almost the same and not comparable to almost all other asia brands. Tolerances on Compass aluminium and CF Parts are really thight! Important sizes will be checked by a protocoll of the QC. CF Parts have total clear edges and perfect fit! Never had a cf part running out of tolerance. Only a few third party manufacturer are involved in the production of compass helicopters. That the boommaker, canopymaker and plasticinjection. Some very easy aluminium parts like crossmembers are outsourced to. Compass use very high quality milling tools and the CNC machines are in good condition. Compass use really good aluminium like 7075 and 6061. I spend one week at Compass a few weeks ago and I can tell you, there are no poor childs working in this 3rd world factory. Its kind of funny to hear people make a judgement about something the never saw before. China is not the China you know from something bad in television. There are a couple of corners - more modern than Germany! I was in factorys for electronic devices and I can tell you. Its clean like an operation room in the hospital and no single employe spend the whole day in toxic smoke. I would say - and guys I know Mikado and Henseleit and all the other noble Brands from Germany very well. Owned some machines from then and also know the guys behind those companys very well - that Compass is from quality point of view on the same level! I need to accept the fact, that our manuals for the helicopters are not that good - but this will be changed with the Warp three sixty.
Team Compass Model - Kontronik - Rapicon - MTTEC - KBDD - MKS |
#14 |
Formerly BarnStormer
Thanks for the info Seb!
BTW I think it looks as much like a Beam as it does a TDR.
"You can still call me Barn To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. " Team Compass USA ProStarHobby.com Scorpion Power Systems |
#15 |
Yeah, all that's true, but it's really still a TDR!
![]() ![]() Scott (j/k)
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Spartan Vortex VX1 Inside Team A Main Hobbies/ProTek Field Rep ):> |
#16 |
I think it must be an Air Hogs copy. They both have 2 rotor blades, landing gear and a canopy! Seb must have coppied them too!!!
#17 |
#18 |
Sebastian any idea of the trageted release date for the Warp 360?
#19 |
Didn't mean to be critical just pointing out that these thing's (In my opinion) are nice I like the fact we are going to be seeing more of this in a more affordable heli. Nice work Seb!!!
#20 |
I feel the same way. The TDR does nothing for me, it's just ugly. I'm in the minority, though.
----------------------------- Nick Crego |
