Go Back   HeliFreak > R/C Helicopter Support > Hirobo Nitro Helicopters
Hirobo Nitro Helicopters Hirobo Freya Evo Eagle Helicopters Discussion
Old 04-10-2004, 06:20 PM   #1
chrisb01
Default Shuttle Plus belt problem
I'm building a Shuttle Plus, I follow the book step by step, but the belt seem too short. I pushed the boom about 4mm more into the frame to be able to put the belt around the pulley, now the boom will not come back out. Has anybody had this problem? How did you solve it? Or can anybody tell me how to fix it? :?:
Chris Baez, Jr.
May we live as long as we want to;
And may we want to as long as we live.
chrisb01 is offline        Reply With Quote
Old 04-11-2004, 09:20 AM   #2
rob_jones
Loosen the four screws that clamp the boom into the frames. There is a notch in the end of the tail boom that must line up a stud inside the frames.
The only way the boom will get stuck is if the bolts are still tight or you somehow got some locktite on it. But there is enough play that you ought to be able to twist it slightly back and forth and work it out.
rob_jones is offline        Reply With Quote
Old 04-11-2004, 02:14 PM   #3
chrisb01
The problem is with the belt. The belt seem too short. The only way I can let the boom back out would be to remove the belt from the pulley.
Chris Baez, Jr.
Old 04-11-2004, 08:46 PM   #4
rob_jones
Chris,
Something is not right somewhere. The belt shouldn't be that tight. My first guess would be that it's twisted too much. It should only twist 90 degress. You might have it 270. That would make it too short for sure.
If that's not it, the only other thing it could be is that the tail case is not fully seated on the end of the tail boom. Remove the tail case and be sure it's installed correctly.
I'm really not sure what you mean by this. You have to remove the belt from the pulley anyway. That's the only way to get the tail boom off.
Old 04-11-2004, 09:15 PM   #5
fitenfyr
Chris,
Take the boom off and the belt out.
Take the numbers off the belt and E-mail Jeff@modelrec.com
Ask him to verify that the belt is correct. Maybe you got a bad belt for some reason. Stranger things have happened.
While the boom is off measure it to ensure you haven't gotten a Sceadu boom by mistake (you didn't say, but I assumed you are building a kit from NIB).
Now when you put it all back together follow the suggestions here and ensure you are doing everything correctly.
If it doesn't fit then. You have to have a wrong part somewhere.
I remember the Plus belt being tight to go on, but you should have some slack in it to adjust out once it is on.
Jason Stiffey
FLY FAST.....LIVE SLOW
fitenfyr is offline        Reply With Quote
Old 04-12-2004, 07:45 AM   #6
chrisb01
Thank you guys. I'll remove belt, boom and tail assembly and put it all back together. I know I must be doing something wrong some where. If that does not work, then I'll email Modelrec. I will get back to you guys with the results. Bimmer and Jason I really do appreciate your helping me with this.
Chris Baez, Jr.
Old 04-12-2004, 07:47 AM   #7
chrisb01
Yes I got the kit NIB.
Chris Baez, Jr.
Old 04-12-2004, 09:07 AM   #8
rob_jones
Cool. Please do. I'm curious to see how it turns out.
No problemo. That's what it's all about!
