| Electric Helicopters - Only E-Helis *No Commercial Ads - E-helis Only |
I have for sale a Trex 450 SE V1. It is almost ready to fly minus the Gyro. I had to keep it due to Sponsorship. (sorry) It has a Futaba 146IP PCM recv. on channel 34, Futaba 9650 servo for the tail, 3- hs55 servos, 430L Motor, Carbon boom, New Align carbon fiber blades. It also has a brand new never flown canopy with new sticker sheet. I also have the following items that will come with it.
4- Thunder Power 2100 15C batteries 1- Mega 16-15-3 Motor 2- Sets of MAH 315mm Blades 1- Set of Align 325 Pro wood blades 1- Set of Align 315 Pro wood Blades 1- Set of Maverikk E-Series blades I think these are 315mm 1- Set of Align 315 Carbon Blades 1- Set of Align Fiberglass yellow blades (paint stirrers) 3- HS1124T Bottom plates 2 new in plastic and 1 used but still good 2- Metal booms 2- Carbon Fiber vertical fins one is used and 1 is new 2- Plastic horizontal fins both new 1 white and 1 yellow 1- Plastic vertical fin white used 1- used but good one way bearing 2- new lower gears 1 blue 1 white 1- HS1013T-2S Metal tail drive gear set (blue) 1- HS1046T Flybar paddle set 3K (new) 2- HS1101T Landing gear white (new) 1- HS1208T Tail rotor blades (new) 2- Boom supports (new) 5- Standard Flybars 2- 220mm Flybars 1- HS 1234T Tail ball link set (new) 4- Skip pipes 2- Main shafts 3- HT1003T Tail belts 1 new 2 used but in fair condition 1- New Castle creations Phoenix 35 ESC never even soldered 1- Motor mount used but good 6- Spindles 1- Tail output shaft with metal pulley 2- boxes (Futaba servo type) Full of spare screws and other parts 1- One way bearing removal tool 1- Lower frame carbon fiber *** Also there are some other small parts too many to list I will let this all go for $675.00 shipped within the US add 3% paypal so the toal would be $695.25. PM me if you have any questions. If you do not need the Futaba 146IP receiver deduct $50.00. I also have some spare gear sets for the hs55 servos. |
Reduced to $750.00 plus 3% paypal which would be $772.50
New price $675.00 plus 3% paypal.
Are you willing to let any of the spare parts go separate? If so can I get a price on the 325 pro woodies, the main shafts, tail belts, and metal booms.
Thanks |
will you take $600 (via paypal) shipped? I do not need the futaba receiver.
Thanks in advance. Brin
Just spent MORE $$$$ T-Rex 450SE V2 Silver JR 10X Heli/Spektrum DSM2/AR6200 JR DS285(with Metal Gears)JR 3400G - G770T/JAZZ 40-6-18/MEDUSA BEC TP1010C/V210 Balancer/Alinco DM-330MV Power Supply RealFlight G3.5/JR 10S Heli NOW parts, parts, and more parts.... |
#6 |
PM sent
