Go Back   HeliFreak > R/C Electronics Support > Align 3G FBL System > Align 3GX FBL System
Align 3GX FBL System Align 3GX FBL Flybarless System Software and Hardware Support
Old 01-04-2012, 04:15 AM   #1
JAG1
Question help with 3gx and futaba 8FG please
hi,im trying to setup my first 3gx 500!! i used to be a die hard flybar fan,and i still am untill i get this bloody thing setup!!!
in my swash menu on my 8FG,do i leave AIL ELE PIT all at +50% for the DIR setup? like you would on a flybar setup?? so i can get everything level.
also can i still use sub trim to get servo horns level??
i feel like a newbie all over again but i like it!!
cheers people
align 450 se v1,SOLD IT!!! got a 450 pro now!!!!!
align 500,it's built!! yes it's in the air!!
Blade Nano CPX
JAG1 is offline        Reply With Quote
Old 01-07-2012, 05:57 AM   #2
Steve Evans
Enter DIR mode so the servos are unaffected by mocement of the heli.
Setup the servo direction for AIL/ELE/PIT servos so they all move in the correct direction with swash PIT mix set to +50%. Set the sub-trim on each so that horns are at 90deg and adjust the links so that the swash is level at mid-stick with a straight pitch curve (-100,-50,0,50,100) and with the 8FG make sure that hover pitch is inhibited.
Set the swash AIL mix so that cyclic is in the right direction, making the value +50% or -50% as needed. Do the same for ELE.
Recheck that the swash is level at mid-stick.
Then set the swash PIT mix to give +12deg at full stick. Then do cyclics at about 8-10deg.
You can then do the E.LIM type stick twiddling as per the manual.
Steve
Trex 450SEv2/HS65-MGs cyclic/Spartan Quark/DS520 tail
Trex 450ProV2 DFC/CGY750 FBL/DS410s cyclic/DS520 tail
Trex 500ESP DFC/CGY750 FBL/YGE-120LV ESC/DS510s cyclic/DS650 tail
Futaba 8FG 2.4GHz
Steve Evans is offline        Reply With Quote
Old 01-10-2012, 11:18 AM   #3
JAG1
Cheers mate,if u don't mind I will PM u as I've just bought a sbus and have a load of questions!
Cheers
Blade Nano CPX
