Old 01-04-2012, 11:12 PM   #1
737A&P
Default Need help with DX6i
I just purchased a Dx6i to use with my new Phoenix Sim (my LHS was out of stock of the Phoenix sims with transmitter), and I eventually want to bind it to a mCPx but I have a few questions about my transmitter since I'm new to all of this.
1) When I do get a mCPx, how do you activate the "idle up" mode with the dx6i? I've watched a lot of youtube videos of guys idling up their helis and some of them flip a switch on their transmitter to go into idle up.
2) What section in the dx6i to I go to in order to change the pitch of the blades so that on my collective stick I have both positive and negative pitch of the blades, with center stick being 0 pitch?
737A&P is offline        Reply With Quote
Old 01-04-2012, 11:38 PM   #2
Skiddz
1) follow the instructions. It'll walk you through everything.
2) You need to go into pitch and throttle curves to change that. If you don't understand that, watch this:
http://video.helifreak.com/?subpath=...=curves101.wmv
-Kevin
Skiddz is online now        Reply With Quote
Old 01-04-2012, 11:43 PM   #3
memosteve
On the DX6i, the "idle up" switch is the switch labeled "GEAR/F-MODE". The switch is located at the upper left side of the radio above the switch labeled "TRAINER".
In order to achieve an equal -/+ pitch range, you would run a linear curve (0, 25, 50, 75, 100) in the pitch curve menu of the radio (on the DX6i, it's labeled as "PITC CUR").
You will also need to run either a flat throttle curve, or a "V" curve in the throttle curve menu (DX6i, "THRO CUR")...
HeliDirect.com Team Pilot/Rep
Align T-Rex 700LE FBL, OS 91HZ-R, Hatori SB-20, Beast X
Align T-Rex 600LE FBL, OS 55HZ, Beast X
Outrage Velocity 50N2 FBL, OS 55HZ, Beast X
memosteve is offline        Reply With Quote
