Go Back   HeliFreak > R/C Helicopter Support > Turbine Helicopters
Turbine Helicopters Turbine R/C Helicopters
Old 01-05-2012, 06:48 PM   #1
DDragon
Default Wren predator balance questions, looking for opinions from previous owners
Hi folks,
Now that I have the trex744 setup the way I like it I thought I'd give it a try on the old wren 54 predator. I know that this is a pretty old setup and there are few around, but I was wondering if anyone could share their experience.
The biggest problem I have is with center of gravity. It's very nose heavy and I found that the only way to compensate was to put some lead weights on the tail fin. I'd rather not do this, but again I may be fighting a loosing battle and this bird may just be too nose heavy .... Period.
I'm running the basic predator air frame with all the metal goodies. I'm using the smallest batteries I could find, but all the electronics are still on the front end.
Would anyone else like to share there experiences with this?
Thanks.
Cheers, Deron.
Too many helicopter and not enough time:
Trex 744 turbine, PredWren, Trex 600, Trex 500, Trex 450. Anyone wanna buy a helicopter?
DDragon is offline        Reply With Quote
Old 01-06-2012, 02:36 AM   #2
MattJenner
hiya,
is there any chance you could put up some pics?
ID:	278507   Click image for larger version
ID:	278508   Click image for larger version
ID:	278509   Click image for larger version
Name:	wren build (14).jpg
Have Fun
MattJenner is offline        Reply With Quote
Old 01-06-2012, 08:39 AM   #3
cbergen
Deron, Are you still running the standard length boom, or have you lengthened it and running 800+mm blades?
Chris D. Bergen
Bergen R/C Helicopters
cbergen is offline        Reply With Quote
Old 01-06-2012, 11:35 AM   #4
DDragon
Originally Posted by MattJenner View Post
hiya,
Hi Matt
I have a bunch of pics on the forum here for went I first showed everyone. I'll see if I can find the link and get the pics. But it looks almost like yours.
How's the balance on yours?
Cheers, Deron.
Old 01-06-2012, 11:39 AM   #5
DDragon
Hi Chris
I'm running the condor boom and the longer blades. 810 or 815 I believe.
I saw Mike has twin tanks on the side and uses that area for electronics on his condor wren. I thought of doing that?
Cheers, Deron.
Old 01-06-2012, 01:33 PM   #6
DDragon
Finally found it.... here's the thread with pictures Matt:
http://www.helifreak.com/showthread.php?t=112224
BTW... just pulled it apart. I noticed that two screws "fell out" from the clutch shoe attached to the aluminum hub.
I was wrong.... the ones that feel out were broken, and the remaining two were broken but the heads hadn't fallen out. I've been flying like that for I don't know how long. But it doesn't look like it's been spinning in the hub.
Cheers, Deron.
Old 01-09-2012, 08:15 AM   #7
ppridday
I put my flight pack and ecu pack on top of the fuel tank at the back. It brought the CG back a bit. This was still with my regular boom and 720's. Should be pretty good with the Condor setup. Unfortunately it looks a little bit cobbed together... It would be nice to have it looking more 'finished'...
Paul
I love the smell of kero in the morning....
ppridday is offline        Reply With Quote
Old 01-19-2012, 10:31 AM   #8
MattJenner
D
Did you get it sorted matey ?
As you can see from my photo's it is possible to get it level, as in my picture the swash is level and the fuel is slightly higher at rear,it does hover tail down slightly.. but only slightly..
If you need any more help just shout out..
All the best
Matt
Have Fun
Old 03-01-2012, 03:08 PM   #9
DDragon
Default Update
Hi All,
Well as an update. I was finally able to get things straightened out. I had to order a new clutch show and bell from Century which took a while and some parts for the battery holder shown in the pictures as well as the gas bottle holder... they were nice and cheap, made well and fit nicely for my uses. But it took almost a month to get them.
Anyway, taking my ideas from Gizmomans build, I moved as much as I could to the back. With the 820 blades and tail everything seems to be much better in the balance arena.
I took her for a short test flight with a half tanks of gas and everything seems well balanced. As the fuel emptied they was a "slight" shift to the front. But nothing uncontrollable.
So anyway... I think she is now balanced.
Cheers.
ID:	294933   Click image for larger version
ID:	294934   Click image for larger version
Cheers, Deron.
